View Poll Results: What type of transmission do you have in your truck? | |||
3spd Manual | 14 | 11.11% | |
4spd Manual | 22 | 17.46% | |
Powerglide | 3 | 2.38% | |
Turbo 350 | 44 | 34.92% | |
Turbo 400 | 27 | 21.43% | |
700R4/Overdrive | 16 | 12.70% | |
Voters: 126. You may not vote on this poll |
07-15-2002, 11:06 PM | #1 |
Cowboy Fan for Life!!!!!!
What kind of transmisson do you have in your truck?
What do you have in your truck?
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
07-15-2002, 11:14 PM | #2 |
its all about the +6 inches
Add anotehr TH350 in there...i could only vote once.
07-15-2002, 11:21 PM | #3 |
My fault , when I set the poll up I was figuring you could only have one tranny in your truck, wasn't thinking about multiple trucks......Sorry...................JB
07-15-2002, 11:52 PM | #4 |
Registered Cruiser
456 Saginaw 4-speed (from 82 camaro) Hurst shifter .373 gear
I intend to live forever. So far, so good. |
07-16-2002, 01:15 AM | #5 |
turbo 350 with a R.V shift kit and a 1900 stall
1972 C/10 LWB 1972 K/5 Blazer |
07-16-2002, 01:44 AM | #6 |
Recovering Truck Driver
I have a TH350 in the 72, and a 700R4 in the Jimmy
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
07-16-2002, 03:03 AM | #7 |
Hammer On!
As far as i know its the original TH400 in mine..... i noticed though that its the tube filter when i was changing my fluid, instead of the flat filter, wasn't that a 67 thing and changed in 68 or was my truck just a lucky one to get the tube? I can get the numbers off the side to check if it helps, i think i would like to know!
Aaron
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
07-16-2002, 07:36 AM | #8 |
67-72 Addict!
350 Turbo w/ shift kit
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-16-2002, 09:21 AM | #9 |
Suburbans RULE!
TH350 rebuilt by yours truely and a TCI TranScat Super II shift kit and 1900rpm stall.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
07-16-2002, 09:26 AM | #10 |
Runing a manual 3 speed Saginaw now but I'm looking for a 4 speed overdrive.
07-16-2002, 11:35 AM | #11 |
Location: Help! I'm in an office park with its own network of freeways!
NP435CR. Good trans, but a 4.56:1 1st is just too high. Not enough gear reduction or torque multiplication. An SM420 or CH465 would be perfect.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
07-16-2002, 02:35 PM | #12 |
700R4 with a shift kit.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
07-16-2002, 02:39 PM | #13 |
Original three-on-the tree.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
07-16-2002, 07:02 PM | #14 |
Car Knocker
700r4 with shift kit, lockup converter, 19 mpg with 3.73 gears
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
07-16-2002, 10:55 PM | #15 |
I have a passenger car M20 4 speed.........
07-17-2002, 01:04 AM | #16 |
What about a 5 speed? Anyone else besides me and Huck have one?
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft. 1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power. |
07-17-2002, 01:26 AM | #17 |
700R4. Loving every mile with it too.
07-17-2002, 02:00 AM | #18 |
Who's running the powerglides?
1969' LWB [Work in Progress] |
07-17-2002, 08:53 PM | #19 |
FIVE SPEEDS RULE!!!!!!!!!!!!!!!!! Unless you are in traffic, or have a cramp in your left leg, or need your wife to use the truck for a day or so, or need to move about a 1/2 inch to line up the trailer hitch. 96 chevy 1/2 ton 5speed = light weight, strong, cheep, and very practical for most applications---with 20-22mpg hgwy. (:>)
07-17-2002, 09:40 PM | #20 |
ROCKCRUSHER
Locked and Glocked 69/C-10 L79 M-22 |
07-17-2002, 10:22 PM | #21 |
Im not for certain on what tranny I have. Im going by what the guy who sold me the truck said.....400T. It does have a shift kit in it cause It shifts kinda hard especially at high rpm's. Anyone here know how I can tell?
350/.30 400 Turbo Trans 3.73 Rear end |
07-17-2002, 10:28 PM | #22 |
350 th w/ manual valve body B&M special
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-18-2002, 01:30 PM | #23 |
TTT
07-18-2002, 02:36 PM | #24 |
Glad to see im not the only one with that little tiny 3speed
07-19-2002, 12:37 PM | #25 |
5 spd from old Camaro
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
