Vintage Evil
LED Gurus I got a question
I bought some plain 2 wire round LEDs from a place that sell semi stuff. If i hook them up to the turn signal wires one way they work as turn signals when the headlights are off but not if the HLs are on. If i reverse the polarity it is the opposite. (they work as parking and turns when the HLs are on but not at all when they are off)
I do not have a LED flasher unit and this is my only idea but does not sound like an answer to me. Thanks in advance for any help ![]() |
its all about the +6 inches
Re: LED Gurus I got a question
It's not going to work, you basicly purchased a single filiment light, like aback up bilb... 1156, you need an 1157, daul filliment buld.
More Cowbell....
It has NOTHING to do with your flasher choice.
LEDs are polarized (+ & -). Regular push-in wedge bulbs are not (You can install them either way). You basically have to pick one or the other of the two ways you say they work....or buy a second set and drill new holes to mount them in your light housing. I had the same exact issue with those bulbs in my Z-71.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 01-06-2006 at 10:59 AM. |
#4 | |
Vintage Evil
Thanks guys Unless someone else has an answer Last edited by chevyguy_72; 01-06-2006 at 01:49 PM. |
![]() Join Date: Sep 2005
http://www.superbrightleds.com/cgi-b...gi?product=CAR direct push and turn lights with leds
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Those lights suck. You can put them in front since those lights aren't all that important, but don't put them in the back.
#7 | |
Licensed to Thrill!
Those people are smoking some crack. Innovative or not - that is just flat out crazy. I could fabricate an entire lense lit up with LED's for less than what they want. |
![]() Join Date: Mar 2004
if you add a diode bridge "rectifiyer" between the power sorce and the LED setup the LED's may work wheather your headlights are on or not.
a diode bridge/ rectifiyer is typicly used to convert ac to dc voltage but also works as a polarity controller when the input power is all ready dc voltage. no matter what the polarity is going into the the diode bridge/rectifyer the output will allways be in one direction thus solving your problem. i hope this helps somehow however if i just confused you even more i appoligize for my geekyness. |
