Old 01-06-2006, 12:45 AM   #1
muddpile
muddpile's Avatar
Shaving antenna, where to put it?
I have my cowl off the truck right now, along with every other body panel, and before I repaint it, I think I want to shave the antenna. I always thought it looked kind of goofy up there, and my stock antenna is thrashed, so moving it is the obvious answer. How hard is it to fill in the hole, and where does everyone usually relocate an antenna to? I will be buying a new one, just not sure which new one. Any suggestions? Thanks!
muddpile is offline   Reply With Quote
Old 01-06-2006, 01:20 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Shaving antenna, where to put it?
Just a little sheet metal welding... no big deal. You may have to contour the plug you make a little for a smooth fit. There are stockers with no hole but may be hard to find.
The Harley guys have powered antennas for the full-dress bikes. Its a little black box you can hide anywhere. You could also just put the stock mast behind the dash. Should be OK around town, not so good on road trips...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-06-2006, 01:24 AM   #3
shifty
Questionable
shifty's Avatar
Where to move it? Where the gas cap used to be
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-06-2006, 01:42 AM   #4
Frizzle Fry
Frizzle Fry's Avatar
http://www.stylinconcepts.com/part.a...6&scid=froogle
Frizzle Fry is offline   Reply With Quote
Old 01-06-2006, 02:35 AM   #5
BowTieMan
BowTieMan's Avatar
I shaved mine and just temporarily put the antenna under the dash an I get great resception.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 01-06-2006, 03:08 AM   #6
muddpile
muddpile's Avatar
The gas cap is actually still there shifty, but I thought about frenching it into the passenger side. I'd move my tank, but I got rear ended by an import sedan and it ended up right where the blazer tank would have been. I really like the look of that autoloc one though, completely hidden, and if it gets good reception, that's all that matters to me. It says no AM, but I can't think of a time I've ever listened to AM (except in the truck, because it was better than the sound of wind).
Old 01-06-2006, 08:11 AM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
Here's the Autoloc antenna on Ebay for about the best price. I put one in my truck and it gets good reception although I haven't been out of town with it yet.
http://cgi.ebay.com/ebaymotors/AUTOL...spagenameZWDVW
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-06-2006, 09:43 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have mounted them under the cowl, and never had a problem at all.
Old 01-06-2006, 09:50 AM   #9
cdowns
cdowns's Avatar
pick a good cam a set of carbs and exhaust!!! removes the need for artifical noise
Old 01-06-2006, 12:38 PM   #10
jhow66
jhow66's Avatar
Put it under the carpet--works fine.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-06-2006, 01:31 PM   #11
70rs/ss
70rs/ss's Avatar
Not to jack the thread, but I have a radio delete cowl, but some dumb @ss drilled a flippin' hole in it!! It is not nearly as big, but what a dumb@ss!!
70rs/ss is offline   Reply With Quote
Old 01-06-2006, 01:55 PM   #12
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I have one similar to the auto lock that i bought at advanced auto parts. It is not totally hidden. I mounted in between the mirror and the headliner. It does a pretty good job.
chevyguy_72 is offline   Reply With Quote
Old 01-06-2006, 03:20 PM   #13
72MARIO
72MARIO's Avatar
Mine is under the passengers feet. It works oky to get local stations. Never mind it was $4.99 at walmart.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-06-2006, 03:37 PM   #14
BowTieMan
BowTieMan's Avatar
Is it just a plain old thin anntena or is it ment to be hidden?
Old 01-06-2006, 03:57 PM   #15
72MARIO
72MARIO's Avatar
Nope it about 14" long plastic one. It's under the carpet and padding. Nobody ever notice it there.
2005 TAHOE DD
