Old 01-06-2006, 11:08 AM   #1
truckdude239
truckdude239's Avatar
headers
okay looking at my up coming build i am starting to look at headers i find some from advance auto call flowtech ( Flowtech Headers: Standard; Chevrolet/GMC Trucks Small Block; 1-.50" Primary Tubes To 3" Collector Size; Black) for 89.98 a piece http://www.partsamerica.com/ProductD...e=1359&ptset=A
has anyone ever used flowtec h headers if so are they worth the money?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-06-2006, 11:23 AM   #2
72MARIO
72MARIO's Avatar
Re: headers
I had them on my 84 besides lasting 2 years before rotting out and changing the gaskets Bi monthly because of the thin flangs. They are oky.
In other words buy a good set of Hooker or Heddman's along with copper gaskets and you will have a trouble free system.
Also 1 5/8 to 3" would be better sizing. IMO.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-06-2006, 01:34 PM   #3
70rs/ss
70rs/ss's Avatar
Re: headers
I kike the Hookers better and I run both. The copper or deadsoft aluminum is the way to fly for gaskets. Flowtechs have a oblonged hole, not round nor sqare and that makes the gaskets blow out because of the port mismatch.
70rs/ss is offline   Reply With Quote
Old 01-06-2006, 01:36 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: headers
Some ppl will swear by $100 headers, but they probably never ran good headers though.
Some high quality headers like hookers will outlast cheapies by many years. Not to mention there will be less headache installing them, and working around them.
Old 01-06-2006, 01:38 PM   #5
truckdude239
Re: headers
thanks i'll spend some more money and get so good headers
David fuller
2000 Tahoe 5.3l 378
Old 01-06-2006, 06:34 PM   #6
crazy longhorn
Fabricate till you "puke"
Re: headers
If you go through Summit Racing, or Jegs, you can get the painted Hooker comps for around $150 shipped to your door. the Supercomps, or ceremic coating gets very pricey tho! I run the Comps (painted, for my budjet), & love em L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-07-2006, 02:48 AM   #7
BowTieMan
BowTieMan's Avatar
Re: headers
Ya I heared flowtech was junk so I went the next step up and got my hedmen hedders and I lvoe them. But I did have to grind the fram a little bit to get the drivers side to fit.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 01-07-2006, 12:39 PM   #8
Batmat
Re: headers
I installed a set on a nova project a couple of years ago. The headers looked good, but once installed, I should have bought stock in a gasket company. I had lots of trouble keeping them on and tightened up. Thin flanges. I replaced them with Hookers, it was money well spent. I bought from summit.
Batmat is offline   Reply With Quote
Old 01-07-2006, 01:26 PM   #9
DangerBoy
Re: headers
Ive been runnin the flowtech headers for the last 6 years with no problems other than the collector gaskets blowing which was fixed with a 2 and a half inch donut from regular exhaust manifolds placed inside the collector by the guy who did my last exhaust setup.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
