Got Horsepower?
excessive oil consumption
i had the motor in my truck rebuilt about 30,000 miles ago and for about the last 6 months or so it has smoked on startup. i changed the oil 2 weeks ago and when i checked it today(600 miles since oil change) it was already down a quart. that seems a bit excessive to me. if it is smoking on startup does that mean that oil is getting past the valves due to worn guides/seals?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Re: excessive oil consumption
If you never had that problem to start with it could be rings or getting past the valves due to worn guides/seals.
Did you happen to switch valve covers recently ? My motor fresh rebuild used oil about a quart every 600-800miles. I went back to the engine builder. He said to remove the PCV and put a breather in the old PCV hole. Problem solved. The PCV was sucking the oil out of my Edlebrock valve covers baffel and injecting it into the intake.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Fabricate till you "puke"
Oil smoke on startup in the morn, does indicate loose valve guides/bad seals. That will be common with that quart per 5-600 miles also. The chevys dont have much of a seal from the factory(just a set of O rings under the keepers), & the steel umbrella. If you tear it down to freshen the top, I would insist on bronze liners, or 1/2" cast guides (no knurl job!), & also opt for a set of seals that push on the guides. the positive type seals will require some machine work on the OD of the guide, but will keep you sealed after you do get a little wear on the stems/guides. best of luck,
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I agree with crazy longhorn.
My when I parked my truck one winter it was roughly 700+ miles per quart. Come spring when I start it up, puff. Blue smoke ever since. Then is started using a quart every 400-500miles. When I did the engine swap out of there and took the intake off, I could see the oil just puddled in the head coming down from the valves. Didn't know it could puddle in there.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
#5 | |
![]() Join Date: May 2004
Got Horsepower?
the heads were rebuilt with the rest of the engine with bronze guides. i figured that guides and seals would last longer than 20,000 miles. do i need to worry about it or can i just run it like it is. im planning on getting a new diesel pickup probably in August and then tearing the '71 apart and completly redoing it(wheres the cutoff wheel im thinkin shortbed) so i dont want to invest much more into it since i'll be getting rid of this motor then(i'm drooling over those 502 crate engines) so this motor only needs to run about another 10,000 miles or so. will it make it?
![]() Join Date: Jul 2004
You can run with worn guides a long time. You might use 15 quarts of oil then in that 10,000 miles, but still cheaper than getting heads fixed.
I see you have an aluminum intake, might want to try tightening the intake bolts some, sometimes they loosen up and can suck some oil in that way, it's a longshot, but worth a look.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 01-07-2006 at 02:52 AM. |
Designated A-hole!
I've seen trucks run forever with leaking valve guides. Kind of a Chevy thing, like leaky rear mains.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Yeah you can drive it for a long time but you will also find a nasty side effect of plugs fouling. Had to do this every 1,000 miles or so. Eventually you know which valve seals are leaking and you only change those plugs. Major drag if you use it as a daily driver. Eventually the cylinders are going to get pretty carboned up. You're always buying plugs-n-oil. Drag. I'd fix it w/only 30K on the rebuild.
Got Horsepower?
yeah i havent looked at the plugs since i put them in a year ago ago. fouled plugs would probably explain why it is running a little rough at low rpms. it is my only ride right now so i cant afford to have it apart. im planning on getting rid of this motor when i re-redo the truck so as long as is is alright till the end of the summer i think i'll leave it alone. I think i'll check those plugs tomorrow when it is light though
