Old 01-06-2006, 08:03 PM   #1
smokinn
smokinn's Avatar
hood problems
The hood on my truck dosent close all the way down in the back. What could cause this? I was looking at it and its not hitting the rubber stoppers. Could it be the hinges are to old and need new ones?
Jason
smokinn is offline   Reply With Quote
Old 01-06-2006, 10:06 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: hood problems
hinge adjustment needed? you shouldn't need new hinges unless the springs are shot. loosen the bolts abit and close the hood push it down to where you want it and reopen and tighten the bolts. This can only happen if you loosen the bolts just right. Too loose and the hood will not stay put. too tight and the hood will not move.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-06-2006, 10:11 PM   #3
smokinn
smokinn's Avatar
Re: hood problems
ok will try that tomorrow thanks
Old 01-07-2006, 12:15 PM   #4
WLPTMP
Active Member
WLPTMP's Avatar
Re: hood problems
its either sprung/misadjusted hood or some of the aftermarket hoods arent very strong and will require a lighter or no spring
WLPTMP is offline   Reply With Quote
Old 01-07-2006, 02:52 PM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: hood problems
OR your hood is bent.... I suffer from bent80andbeforehood-itis.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 01-07-2006, 07:10 PM   #6
smokinn
smokinn's Avatar
Re: hood problems
I tried the bolt thing and now its worse. I think im going to look for new springs and see what happens.
Old 01-08-2006, 02:49 AM   #7
hotrodhomi
hotrodhomi's Avatar
Re: hood problems
just keep adjusting it. you will need to ajust the new springs anyway. Don't throw your money away.
'66 impala ht
Old 01-08-2006, 12:27 PM   #8
SSC's76
No No
SSC's76's Avatar
Re: hood problems
Alot of times the hinge rivit gets worn and alows what you describe. I'd inspect the rivit and the slot for wear. In the past Ive been able to use the MIG and add some material to the pin and this cured the problem.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
