01-06-2006, 08:25 PM | #1 |
Truck Farmer
One wire alt ?
I put the newer style alternator with the surpentine drive from an 86 and now need to energize it. Wires are black and pink with a black stripe. I am assuming the black would be for the amp guage and the pink with black strip could be hook straight to the hot on the alternator. Is this right or am I anal. Anyone know for sure? Thanks
Arizona rust free sheetmetal |
01-06-2006, 10:34 PM | #2 |
its all about the +6 inches
Re: One wire alt ?
is this a one wire... or a 3 wire?
01-07-2006, 12:18 AM | #3 |
User #12137
Re: One wire alt ?
go here and scroll down the page to find what ya need to look for
http://www.madelectrical.com/electrical-tech.shtml |
01-08-2006, 09:20 AM | #4 |
Truck Farmer
Re: One wire alt ?
Its a three wire, one lug for hot, and the regulator plug. Didn't find what I needed on the link either. I was thinking I could run the hot to the pink/black striped wire on the regulator and it would work.??
01-08-2006, 10:34 AM | #5 |
Re: One wire alt ?
One wire alternators, I have purchased only one of these and maybe it wasnt working properly and maybe some one can clear this up for me. On the one wire alternator I purchased when starting the vehicle the alternator wouldnt charge unless I reved it up is this normal?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
01-08-2006, 10:55 AM | #6 |
Re: One wire alt ?
here try this it is for wireing an internal reg alterantor http://67-72chevytrucks.com/vboard/s...d.php?t=119379
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-08-2006, 12:19 PM | #7 |
Re: One wire alt ?
bowtie, that is normal.
01-08-2006, 08:04 PM | #8 |
Re: One wire alt ?
Wow! I could have made a bunch-O-Bucks on this one because I did this on my 56 Chevy Pickup over 20 years ago, with a regular alternator, I should have patent it, oh well, maybe next time.
01-10-2006, 12:45 AM | #9 |
Re: One wire alt ?
hotrod did any of that work for you did you get it wired?
01-10-2006, 04:16 PM | #10 |
Truck Farmer
Re: One wire alt ?
No, I just wanted some conframation on the wires. I have been doing this conversion for lots of years also and understand everything said here and on the links, however this is the newer style and was just asking a question if someone could identify the wires. Here is a pic of the plug
01-10-2006, 06:06 PM | #11 |
Re: One wire alt ?
I have a 1 wire alt out of a 89 chev truck and it is inly 1 wire(brown) in the plug you posted a pic of. Ran it to keyed "hot" then connected a larger wire from the lug on the alt to the battery. Worked for me.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
01-10-2006, 06:16 PM | #12 |
Re: One wire alt ?
The would be a 2 wire.... one wire alt would have.... one wire.
It would be aftermarket, and not stock. And I'll bet a kick in the daddy parts, that you'll NEVER see one in the junk yard. |
01-12-2006, 01:34 AM | #13 |
Re: One wire alt ?
I have a 1 wire alt on my 72 truck, it is a A/C delco part
My original alt with the external regulator quit so I put the 1 wire alt on as it is a quick install There is only 1 wire from the alt to the battery but there is no provisions to hook up the amp guage and the output is fairly low (about 40 amps) I will probably change to a 3 wire stlye when I need more power output, like when I actually get a radio installed
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
01-12-2006, 03:38 AM | #14 |
Re: One wire alt ?
What kind of 86 did that come out of? That plug looks newer than that.
