Old 01-07-2006, 01:27 PM   #1
aggiedave98
small leak in radiator
I thought I'd find a lot of posts on this w/ a search, but didn't find much.
Anyway, I've got a small leak in my radiator. I'm not sure where, but if I crawl under the truck I can see some fluid at the lower point of the radiator. I fill up the overflow tank to the lower line every month or so. It slowly empties (as the radiator is leaking). Probably 6 months ago I put in some sealant that you pour in the radiator.
Should I try some more sealant? Is that stuff bad??
What are my other options? I think I've heard of places that will fix leaks. Is there a good way to find the leak??
aggiedave98 is offline   Reply With Quote
Old 01-07-2006, 01:47 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: small leak in radiator
To much sealant and you can plug the heater core up. I recommend that you find a decent radiator shop and pull the radiator out of the truck and fix it. Shops around my part of the country are not that expensive on small core repairs.
piecesparts is offline   Reply With Quote
Old 01-07-2006, 01:48 PM   #3
aggiedave98
So can I just bring it in and they'll find the leak and fix it?? I'm going to be rebuilding the engine, so I can just do it then.
Old 01-07-2006, 02:06 PM   #4
1983shorty
1983shorty's Avatar
if you are rebuilding the engine i would get a new radiator or get yours recored. a new engine is "tighter" and will run a little hotter . if you can afford it , $150 or so for a new radiator is well worth the money to protect your new engine.
1983shorty is offline   Reply With Quote
Old 01-07-2006, 02:11 PM   #5
aggiedave98
shorty, I'll probably get a new one... I plan on doing the rebuild right, so $150 for a new radiator would be worth it... especially since I put the sealant in there...
Old 01-07-2006, 02:50 PM   #6
piecesparts
A good radiator shop could look your radiator over and tell you if it is worth the effort to clean it out (rod the core) or if you should replace it. I have had more than one cleaned and repaired. I support the idea of buying a new one if it is needed. I had a truck that I chose to do that with, I even bought a core with more rows than the original and my cost was around $100.00 from the radiator shop. I have another truck that I put an aftermarket aluminum radiator in and it cost a lot more, along with the electric fans that I also put in.
Old 01-07-2006, 07:11 PM   #7
smokinn
smokinn's Avatar
On myth busters they put a egg in the radiator to stop a leak and it worked.
smokinn is offline   Reply With Quote
Old 01-08-2006, 08:54 PM   #8
OJOE
Crew Cut
OJOE's Avatar
on a big leak use the whole chicken ha ha
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-08-2006, 10:03 PM   #9
aggiedave98
I watch Mythbusters sometimes, but didn't see that one... that's pretty funny though.
Old 01-09-2006, 01:55 AM   #10
smokinn
smokinn's Avatar
No just use a dozen. LOL
