Old 01-07-2006, 10:22 PM   #1
incoma
incoma's Avatar
Is this goof going to cause problems?
I finally got my vent glass installed in my frame...(not very tough with the right gasket) and screwed up the install. I was so giddy to have gotten the glass mounted in the frame that I continued "fast forward" to install the frame and rivet the sucker into the main frame.
Problem is that I forgot to install this "pivot stop"... I don't want to drill out the pop rivet, because I don't want to buy another kit. Will it hurt anything to not have the "pivot stop" installed?
I'm referring to the washer looking thing that's got one rounded side and one square side. I've highlighted it in yellow and put an arrow in where it should be installed.
I looked at the other side and it doesn't seem to do a whole lot... am I missing something?
incoma is offline   Reply With Quote
Old 01-07-2006, 10:34 PM   #2
Green Machine
Green Machine's Avatar
Re: Is this goof going to cause problems?
Well the pivot stop function - as a stop - is not that important, but it along with the fiber washer helps set the height of the window and gives the tension spring something else pull on besides the pivot rivit. Those rivits can be bought seperately, just drill it out and do it right.
"If you don't have the time to do it right, when will you have the time to do it over ? "
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-07-2006, 10:38 PM   #3
incoma
incoma's Avatar
Where can I buy that special rivet? I'd rather not buy another rivet kit for the entire frame...
Old 01-07-2006, 10:48 PM   #4
Green Machine
Chevy Duty - part # 03-831, $.99 for the pair.
Old 01-07-2006, 10:53 PM   #5
incoma
incoma's Avatar
Thanks. I'll drill it out and fix it first thing in the morning. Thanks for all of the legwork Green Machine!
Old 01-07-2006, 10:58 PM   #6
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I gotta a question also. Can you buy just the spring assemlby part? Mine is broke on the drivers side. the vent window just flops around when opened
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 01-07-2006, 11:01 PM   #7
incoma
incoma's Avatar
I do know that you can buy that section from LMC.
Old 01-08-2006, 08:54 AM   #8
70GMCer
70GMCer's Avatar
do you need a special tool to install that rivet?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-08-2006, 09:10 AM   #9
truckdude239
truckdude239's Avatar
a rivet gun i'd guess lol don't mind me naw i don't know if it take a special gun oir not
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-08-2006, 03:15 PM   #10
incoma
incoma's Avatar
You do need a special fixture. I wouldn't call it a tool really. Its more of a die. It rolls the rivet into a smooth rolled underside.
