Old 01-08-2006, 04:09 AM   #1
carl609
carl609's Avatar
one piece driveline
Whats the word on changing to a one piece driveline in a long bed? Has anyone done it? Any problems?
carl609 is offline   Reply With Quote
Old 01-08-2006, 05:44 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: one piece driveline
Lot's of driveline shops don't wanna make one that long.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-08-2006, 09:12 AM   #3
truckdude239
truckdude239's Avatar
alot of shops won't make one over i think 69 inches
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-08-2006, 11:04 AM   #4
ratrod67
ratrod67's Avatar
I have one in my 72 LWB. So far so good.
ratrod67 is offline   Reply With Quote
Old 01-08-2006, 02:00 PM   #5
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
This subject has come up numerous times here and you'll hear lots of pro's and con's. My suggestion is to go to a reputable driveline shop and have it built the right way.
I have one-piece shafts in both my sons LWB and my SWB and have had no problems at all.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-08-2006, 03:09 PM   #6
70short
What do the newer trucks run? Dont they have one piece drivelines? I run A one piece driveline in my short bed.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-08-2006, 03:15 PM   #7
corn
A friend of mine told me his dad used a suburban driveshaft in his 71. I asked him again to find out the details from his dad. He said its out of a late 73-87 suburban & it bolted right in. I asked him if the 71 has the stock length trans housing in it & he said he will ask his dad. Im still on it, I may just go out there & crawl under it myself to find out. I want one on my long bed too...
corn is offline   Reply With Quote
Old 01-08-2006, 05:46 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A properly repaired 2 pice will be just as strong and offer more flexability than a one piece, but no one wants to go that route.
The new vehicles use one piece shafts, but they are alluminum, and rather large in diameter... like as big as your thigh. ok, as big as a skinney adult male's thigh.
6 feet is the magic number where most places draw the line. A SWB, is no problem, and many came stock with a one piece.
Once you hit 6 feet, a regular mild steel shaft, made in normal diameters, will start to sag a little under it's weight, and then whip at speed. Some shops will do it anyways, and some of those shops really shouldn't do it.
If they make the shaft in thinner metal, and larger diameter, then they know what they are doing, but then you'll have issues with the cross member.
In 73, they moved the engine back further. in addition to that, they started the longh shaft trannys, the two mods together, made a one piece do-able on some models of trucks.
Like I said though, a properly built stock 2 piece shaft will hold more power than your truck will ever make.
Old 01-09-2006, 03:14 AM   #9
Brad
Out of the carpool lane.
Brad's Avatar
I had one built for my lwb w/Muncie 3 speed and it worked great for years! I went through 3 carrier bearings in about the same amount of time and I had had enough.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-09-2006, 06:41 AM   #10
Longhorn Man
I guess it might be easier than finding what's actually wrong, and addressing the real problem.
A good, high quality, properly installed carrier bearing should last 30 years easily.
Old 01-09-2006, 06:46 AM   #11
My 96 had a 2 piece shaft. Still haven't figured out why the same year vehicle, Suburban has a 1 piece, but the ext cab had a 2 piece.
Old 01-09-2006, 08:43 AM   #12
yank
yank's Avatar
That's odd Bill. the 96 ext cab chevy I had back a few years ago had a one piece dive shaft . I had to remove the tranny 3 times in it
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline   Reply With Quote
Old 01-09-2006, 10:17 AM   #13
Lemield
Lemield's Avatar
I agree with Longhorn Man. I had a 70 LWB big block and the PO had installed a M21 4spd and a one piece driveshaft. It was very long and the truck had a nasty vibration at speeds above 40 mph. I had the shaft redone at an excellent shop in the area but it still had a vibration....could have been something besides the shaft. Anyhow, I sold the truck but if I had kept it, I would have put it back to the two piece.
I'm running a one piece in my SWB because I have a Gear Vendors overdrive unit. A two piece in that situation would have made for a VERY short front part of the shaft. So far no problems.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 01-09-2006, 10:38 AM   #14
72 Cheyenne402
72 Cheyenne402's Avatar
I also have an 05 Silverado extended cab trailoring package and power package it has a 2 piece drive shaft w/ a carier bearing although my 02 swb didn't
72 Cheyenne402 is offline   Reply With Quote
Old 01-09-2006, 11:14 AM   #15
truckdude239
when i changed out my transmission i replaced the carrier bearing and i could tell its been on there since 71 and it was still strong i just desided to replace it while everthing was apart. i lornhorn said a good 2 piece driveshfat is just as strong as a one piece
David fuller
2000 Tahoe 5.3l 378
Old 01-09-2006, 02:14 PM   #16
Was your's a 4wd? I am told the 4wd had one piece and 2wd had two piece. On the original subject and like Longhornman mentioned, they will hold up a long time if set upright. My 96's carrier went out at 140,000 because a yoke on the rear end broke and caused bad stuff to happen.
Old 01-09-2006, 02:19 PM   #17
yank
yank's Avatar
Bill no it was 2wd
70 C/10 SWB
Old 01-09-2006, 02:22 PM   #18
Hmmm.. Oh well. Standardization there was not I guess. Maybe it was a GMC vs Chevy thing?...I dunno.
