Old 01-08-2006, 02:37 PM   #1
Destructo
will a 79 or 80 2wd body swap for a 81 K10 frame?
Me and my Fiance are working on a K10 for her, and we have two trucks, the 81 body is shot, the 79-80 body is in better shape but need some patch panels, so I believe the older body will swap right onto the 81 frame, but just wanted to be sure, the only issue we'll run into is the gas tanks are on different sides, but thats pretty easily fixed.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 01-08-2006, 04:18 PM   #2
us111
Re: will a 79 or 80 2wd body swap for a 81 K10 frame?
hello,,what i do know is if your planning on leaving the k-10 a 4x4 and put a 2wd body on it you run into the issue of having to cut out the high hump area out for the transfer case and tranny,i done it on mine and not even a body man so that part can be done,i have also heard with a lift kit you dont have that isuue..just a couple thought's..
us111 is offline   Reply With Quote
Old 01-08-2006, 05:05 PM   #3
Destructo
The 81 K10 has a bolt in tranny hump, were going to swap the tranny humps, I just need to know if all the body mounts are the same, which I believe they are, theres only a 1 or 2 year difference between the body and frame.
Old 01-08-2006, 05:40 PM   #4
us111
i did the same thing,thought i could just bolt in tranny hump,did that,painted everything then realized that there is also a peice that goes back under seat that has to be changed also,if these pic's work you can see in the one pic where just the bolt in hump was done,then where i had to go back and cut out the other peice.
Old 01-08-2006, 07:56 PM   #5
Destructo
I see, luckily that won't be a problem, the 81 K10 cab is junk but the middle of it is good, so we'll have all the parts we need to fix it up.
Old 01-09-2006, 12:13 AM   #6
us111
cool,,if u look on the old 4x4 cab that xtra piece i am talking about is all there and spot welded in,,just get it out,clean it up and put back in 2wd cab floor,,sorry but as far as cab mount's etc. goes i'm not sure about all that other than to say i put a 78gmc 2wd cab on my 76 4x4 frame...good luck..
Old 01-11-2006, 11:54 AM   #7
Destructo
Anybody got a definite answer on if all the body mounts are the same between a 1980 2wd shorty and a 81 K10 shorty?
