Recovering buckets, couple questions
I am recovering the buckets in my Jimmy.
I assume the passenger and driver's seat are the same correct? So the two sets of upholstery should cover either seat correct? The old covers (PO had recovered them) were glued to the center seating area. Do I need to reglue the new ones too?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Recovering buckets, couple questions
The 2 buckets are the same.It's just the mounting brackets that are different.
I didn't glue the new covers on anywhere.Just used the hog rings. Call up a local auto upolstery shop and see what they normally do.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
"Trucks with Class"
![]() Join Date: Jul 2000
You probably won't need to glue them, IF, you take the time & effort to pull and tuck the area all around the center section...where it meets the outer border. This was originally held by metal clips that pushed through the foam.
