Old 01-08-2006, 07:39 PM   #1
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
ignition question
About six motns ago my truck wouldn't start & a friend of my dad checked it out and told me it was the ignition cylinder. He ran a wire fromthe dist. to the battery so I could move the truck. I had to remove the wire from the battery to shut my truck off. I bought the igniton cylinder and Ithink I can install it but my question is what do I do with the wire thats connected to the dist. I don't know if there was another wire hooked there or what. I just thought I'd ask the members their opinion on the diagnosis and the wire before i paid someone to install it.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 01-08-2006, 07:48 PM   #2
incoma
incoma's Avatar
Re: ignition question
There should be a yellow wire that is connected to the distributor. You'll want to reconnect it....
ooppps.. you connect the yellow one if you're running hei. if you are running points...I think you connect it to the coil?? someone correct me please.
incoma is offline   Reply With Quote
Old 01-08-2006, 07:57 PM   #3
Sweet72
Sweet72's Avatar
Yellow wire goes to the + terminal on the coil (points). If there has been a HEI conversion it's hard tellin' what goes where , but there should be a plug that goes directly to the distributor.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-08-2006, 08:50 PM   #4
69moneypit
69moneypit's Avatar
It was converted to HEI a few years back
1969 GMC SWB
Old 01-08-2006, 09:02 PM   #5
krue
Designated A-hole!
krue's Avatar
Charles, look on your fusebox, there should be a blade type terminal between the uses labelled Ign Unfused. You plug your wire from the Distributor into that. It will power the distributor with the key on and kill it with the key off. (that's the way I wired mine when I converted to HEI). I'll try to post a pic of what I mean.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-08-2006, 09:04 PM   #6
pjmoreland
pjmoreland's Avatar
There's some great information on how to wire an HEI distributor in the following thread. Scroll about 3/4 of the way down past all of the inline 6 stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
The way krue describes it will work great. That's how I have mine wired, but I really like the way it is done in Shifty's thread. It's really clean. I'm planning on rewiring mine that way eventually.
pjmoreland is offline   Reply With Quote
Old 01-10-2006, 03:16 AM   #7
jimfulco
If he just removed the original HEI hot wire and let it drop down, it might still be there waiting to be plugged back in.
jimfulco is offline   Reply With Quote
