Old 01-08-2006, 09:18 PM   #1
Russell
Professional Grade
Russell's Avatar
Oops! I did it again!
I just had to go and buy another truck
1977 GMC short step.
Has a good V8 of unknown size - 160 psi in each cylinder. Need a new 4 barrel intake, has a 2 barrel at the moment. The truck came with a carb, in a garbage bag in a million peices
TH350 - PO claims it is a good solid transmission, with no slipping or clunking.
3.08 open rear 10 bolt diff.
The thing has fresh tires all around, new shocks all around, and new brakes all around. The interior is pretty nice too! The dash is gorgeous, has a sunroof, and a reasonable bench seat / door panels.
Bad things:
Mild bend in the frame under the cab. Nothing appears out of square, just has the bottom lip of the frame pulled down.
Needs a new driver's side fender, new door panel carpets, headlights and the seat is getting worn.
The cab light switch is shot, and when you turn the wipers on, they squirt fluid all the time.
Also very rusty. Doesn't have any cab corners, rockers (inner or outer) or floor supports left. The fenders are pretty good n rotten too.
All the above for 350 bucks Canadian
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-08-2006, 09:32 PM   #2
bigarmzz
bigarmzz's Avatar
Re: Oops! I did it again!
160 psi is really good compression
looks like you got a good start to something decent!
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 01-08-2006, 09:55 PM   #3
Lynx
Lynx's Avatar
Looks good, glad i could help your addiction out
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 01-08-2006, 10:04 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
is the stepside bed good? wood in it? bedsides ok? Not that i want to buy it and have it shipped to louisiana or anything...
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 01-08-2006, 10:06 PM   #5
Russell
Professional Grade
Russell's Avatar
lol, the step bed has no floor, the one flare has a dent in it, and there is some rot starting above the steps in the bed side wall. Should be an easy fix. I plan to sell the step bed to make back the money I spent on the truck
Old 01-09-2006, 12:21 PM   #6
Prerunner1982
Prerunner1982's Avatar
Russell, is the bend on the frame on the drivers side? if so.. its suppose to be there.. i dont know when they started that, the 77 or 78 i looked at the other day had it, mine has it and all the other 81+ i have seen have it. From what i remember i believe its there for clearance for the Catalytic converter.. i think thats what i was told.. i thought mine was bent for along time as well. Thought some idiot tried to pull it out of the mud sideways.. until i got under OCBAUDs truck and others.. and realized they all had it.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-09-2006, 12:41 PM   #7
Russell
Professional Grade
Russell's Avatar
Ah, cool!
If thats the case, then a miss-understanding on my part is a main reason for getting the truck as cheap as I did, LOL
Its on the driver's side rail, near the center of the cab
Old 01-09-2006, 12:50 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Cat clearance as Prerunner said, it is supposed to be there.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-09-2006, 07:56 PM   #9
SlapFish
Real Men Wear Orange
Was it really that important to make that stupid bend in the cat and bump the frame, rather than make a straight cat and not mess with anything?
SlapFish is offline   Reply With Quote
Old 01-09-2006, 11:30 PM   #10
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
It's not really a bend in the cat, it's to keep the frame from getting brittle and cracking/breaking from the heat cycling from being that close to the cat. The cats they were using when these trucks were built were the huge pellet type (most of which are long gone I'm sure...) and they didn't have much room to work with even when they did bend the frames. My Gentleman Jim even has that bend and it's a 75.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 01-09-2006, 11:42 PM   #11
SanitysBane
So what truck are you going to sell me Russell? You obvisouly don't have time to finish all of them.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-09-2006, 11:49 PM   #12
Russell
Professional Grade
Russell's Avatar
You can have the 89 man!
Old 01-10-2006, 08:51 PM   #13
SanitysBane
Thats more of a curse than gift.
'88 K5 Blazer
Old 01-10-2006, 09:15 PM   #14
Russell
Professional Grade
Russell's Avatar
lol
Old 01-11-2006, 12:37 AM   #15
longhorn71
longhorn71's Avatar
Russ i have a line on a good 84 cab i will let you know if i get the truck
longhorn71 is offline   Reply With Quote
Old 01-11-2006, 01:27 AM   #16
Russell
Professional Grade
Russell's Avatar
Oh really?
How much were you thinking?
I've got reasonable fenders I can put on it, just need a cab... I can gut and pull one of these cabs in a day, and have it installed and complete the next day, lol
Old 01-11-2006, 06:24 PM   #17
Kybol
Kybol's Avatar
sweet deal man.
-90 454ss http://www.imagestation.com/album/?id=4289115843
-04 TRX450R
-77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD
-82 c-10 SOLD
-02 CRF450 SOLD
Kybol is offline   Reply With Quote
Old 01-13-2006, 02:07 AM   #18
Russell
Professional Grade
Russell's Avatar
Well, I got the truck home tonight with no problems less a messed up tail light harness on my 89, lol
I'll start a new thread with some new / better pics tommorow
