Junior Member
87 instrument cluster Help Please
I was removing my instrument cluster and accidentally disconnected a wire and I don't know where or what it was plugged into. The wire feeds a dash bulb on the upper right hand corner of the instument cluster (above and to the right of the fuel guage). Any ideas where this wire goes? Thanks for all of the help guys!
huh ???
Re: 87 instrument cluster Help Please
If I remember correctly it goes to the ashtray lamp. Either that or to the tranfer case selector...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Professional Grade
Yep that is a fiber optic wire to light up your ash tray
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Yep, ashtray. Just did the same thing. You painting it with the chrome?
Junior Member
Thanks for the reply's. I had to take it apart to fix some of the botched wiring the previous owner did and replace a couple of bulbs, so I thought that I would paint it chrome while its out.
