Old 04-10-2002, 03:41 PM   #1
dubie
dubie's Avatar
Post Tach question
My 72 didn't come with a tach in it, but will the wiring be there for it? I am going to replace the bezel and was just curious if the wiring was done for a tach on all the 67-72's
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-10-2002, 03:44 PM   #2
Desert Rat
Desert Rat's Avatar
Post
No its only in the tach trucks,but its a simple harness to make only a couple wires,one to fuse box other to distributor
Desert Rat is offline   Reply With Quote
Old 04-10-2002, 03:44 PM   #3
Desert Rat
Desert Rat's Avatar
Post
HEI is to dist.points to coil.
Old 04-10-2002, 03:46 PM   #4
Desert Rat
Desert Rat's Avatar
Post
If adding to truck in your signature and you have a 6cyl and using factory take make sure its a 6cyl one not a V8 ,most after market takes you can use either way,by the flip of a switch)
Old 04-10-2002, 04:01 PM   #5
71Chev
71Chev's Avatar
Post
A factory tach can be recalibrated with a small screw driver, for use on a 6 or 8 cylinder.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-10-2002, 04:07 PM   #6
dubie
dubie's Avatar
Post
I will be swapping the inline 6 out in a couple months for a 350. I think i just might have to check into what the wiring harness will cost. Thanks guys
72 C/10 LWB 2wd
Old 04-10-2002, 04:39 PM   #7
blaznorange
Post
Wiring harness costs 18.95 from GMCPauls. I also opted just to buy the harness rather than make one saves on asprin. blaze
blaznorange is offline   Reply With Quote
Old 04-10-2002, 07:55 PM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
uhhhh its one wire to fuse panel, two terminals on both ends and one to distrib.. if you need asprin for that.....
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-11-2002, 08:26 AM   #9
dubie
dubie's Avatar
Post
Ok, I found a pic of it at GMC Pauls website. Good price if you live in the USA, but $18.95 in Canadian, once the shipping and all is included, it's over $45!!
Man you guys in the States got it made when it comes to buying parts. I see cab corners are like $14 at GMC Pauls, we have to pay in the upwards of $40 CDN here. I think i should move to the USA just so I can finish my truck
72 C/10 LWB 2wd
Old 04-17-2002, 05:07 PM   #10
JW
Post
Any 3 3/4" dia tach can be used. I have used 78-86 Camaro and Sun Super II tachs.
To wire a tach, (-)black to back of dash (screw)for ground, (+)red to ignition switch-on, or to fuse panel unfused (use a inline 10amp fuse), green to coil or HEI (tach).
The Camaro tach fits nicely into the dash metal case, the Sun requires alot more work.
72 Cheyenne Super, Fleetside, Shortbed,
Original Owner
Original Owner, Special Ordered
350ci/340hp, Auto Trans, 3:70 Posi, Tow Package
Northern Calif
JW is offline   Reply With Quote
