I'm working on a 69 C20 and have a 67 C10 for parts. Will the control arms off the 67 fit the 69? All the measurements are the same. The only difference I see is the C20 arms have a strap welded to the bottom,
Re: rear suspension control arms
They will fit fine, with the added advantage of the extra bracing.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Fab a new reinforcement for the C-10 trailing arms from mild steel and weld it on.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
