Old 01-09-2006, 06:37 PM   #1
CT-Truckster
CT-Truckster's Avatar
Need Help Quick
ok i got a 88 gmc with a 96 or 7 vortec 350 me and my dad put in it about 5 years ago. theres some kind of oil pressure sensor right above the oil filter on the side of the block, and i can't remeber what its for. the pressure sending unit is on top of the block behind the intake right? anyway the one above the filter has gone south and pouring out oil, can i just plug the hole for now to get this thing back on the road tonight or is this a vital piece the truck won't run without? Thanks in advance for any help.
CT-Truckster is offline   Reply With Quote
Old 01-09-2006, 06:39 PM   #2
bglad420
bglad420's Avatar
Re: Need Help Quick
Pretty sure you can just plug that one if your running another.....
bglad420 is offline   Reply With Quote
Old 01-09-2006, 07:11 PM   #3
chevyfan420
Re: Need Help Quick
maybe a mechanical tube, that got crimped or melted over time? either way you can plug it to get going again. you dont "have" to have a oil pressure gauge, but its advisable
80 Chevy K10 350/350turbo
86 Chevy 1/2 ton shorty project truck
79 Chevy 1/2ton 350/350turbo
not much to look at... ***Retired***
97 Chevy C1500 4.3/5 speed.....daily driver
chevyfan420 is offline   Reply With Quote
Old 01-09-2006, 07:21 PM   #4
CT-Truckster
Re: Need Help Quick
i found this serching some past posts about the oil pressure sensor on the top of the block and the one down by the oil filter
"the reason behind a oil pressure switch, for the choke is very simple. When you press on the pedal, the choke closes. When you start the vehicle, the choke starts heating up, if the switch sees oil pressure. As long as the engine has oil pressure, it receives power. No pressure, as per the switch, no power. The reason is so the choke won't open unless the engine is running. If this switch wasn't used, all you would have to do to make the choke open is turn on the ignition. If this happened, the engine would still be cold, and the choke wouldn't work when you started it up.
Now, after TBI came into the picture, this switch is used to supply power to the fuel pump. Same sequence. After it starts, if oil pressure isn't sensed, it shuts off power to the fuel pump. This is a safety feature. Say you wreck and the engine dies, but the switch is still on. Without the switch, fuel would still be pumping and if a leak were to occur, well you see how this wouldn't be a good thing."
So mine is still got the tbi even with the vortec engine, so if this pressure swith controls the power to the fuel pump, then its not gonna run, so i'm gonna go plug it and find out.
Old 01-09-2006, 08:10 PM   #5
pugs
pugs's Avatar
Re: Need Help Quick
im not familar w/ the later model V8's but i know on the early models what looks like a oil pressure switch on the side of the block was what they called a knock sensor again im not familar w/ later model engines
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 01-09-2006, 08:36 PM   #6
CT-Truckster
Re: Need Help Quick
well, i plugged it and its still running just like always. must be for the oil pressure gauge, maybe that explains why the gauge never worked right, sometimes it would, and then finally just quit working at all. I replaced the oil pressure switch up behind the manifold but it still didn't work, so maybe the one up top is an oil pressure switch for something other than the oil gauge, maybe the fuel pump or something, I don't know. i'll pick a new one to replace the one i removed later in the week and see if my oil gauge starts working again.
