Old 01-09-2006, 11:07 PM   #1
OleBlue69
OleBlue69's Avatar
Gas tank removal
When I try to get the tank out, is there any easy way to get the filler neck to come through the cab without tearing the surrounding gasket all to crap? Thanks for any help!
OleBlue69 is offline   Reply With Quote
Old 01-09-2006, 11:19 PM   #2
qksilver
Re: Gas tank removal
generaly they are dry rotted so hard. If you can soften the gasket it will come out without messing it up. If it is good and dry pretty much all you can do it cut and get a new one.
Steve
qksilver is offline   Reply With Quote
Old 01-09-2006, 11:36 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can spray the rubber down with PB Blaster... or WD40 if that's all you got.... even water will help (maybe more than the WD40 would). As you pull it back towards the passengers side, tilt the tank up. It should come out with minimal fussin and cussin.
Old 01-10-2006, 08:00 PM   #4
OleBlue69
OleBlue69's Avatar
Thanks guys!
Old 01-10-2006, 08:44 PM   #5
shifty
Questionable
shifty's Avatar
I cut mine. Brand new gasket too. I tried like hell and couldn't get it to come through...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-10-2006, 08:54 PM   #6
70GMCer
70GMCer's Avatar
I just had to take mine out today. Had to cut it out. There still available at the dealers. Not that expensive......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-10-2006, 09:19 PM   #7
mjrmn
'67 K10 Work In Process
mjrmn's Avatar
Liquid dishwashing soap works well as a real slippery lube for rubber parts IF they are not too dried out.
Good luck
Mike
mjrmn is offline   Reply With Quote
