Old 07-16-2002, 03:52 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
What does this mean
On the tire P275/60R15 I know its tire dimensions but exactly what does each mean?
68gmcjon is offline   Reply With Quote
Old 07-16-2002, 04:03 PM   #2
lux hauler
Psycho-billy Member
lux hauler's Avatar
here is a link to The Tire Racks web site............
http://www.tirerack.com/tires/tiretech/general/size.htm
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 07-16-2002, 05:14 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I believe it is 275 mm across the tread and the side wall is 60% of that.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-16-2002, 06:36 PM   #4
ThreeQuarter
ThreeQuarter's Avatar
P is for metric passenger car tire (measured in mm instead of inches). Usually these are load range B. LT is for light truck, and can come in higher load ratings. (P-metrics are OK to use on trucks.)
275mm is the section width, includes the sidewalls and whatever amount of curvature they have. Basically the measurement of the tire at it widest point, not including tire squat from a load.
Section height is 60% of 275mm. So the actual measurement depends on width--all 60 series are not the same height.
R is for radial.
15 inch rim diameter.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 07-16-2002, 06:47 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
An interesting note, while gmcblu is 100% correct, you can take 2 tires that are supposed to be the same size from differant manufacturers, and when you measure them, they will not be the same.
makes no sence, but it is true.
