Old 01-10-2006, 05:33 AM   #1
wibilly
wibilly's Avatar
quick ?
i'm stripping my my dash and cab for painting i'm trying to remove the ignition switch while holding the switch i'm unscrewing the bezel it got looser but is just not going any further am i missing somthing here?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-10-2006, 05:40 AM   #2
67chevytrk
Damn I'm broke
67chevytrk's Avatar
Re: quick ?
on my 67 I have to take out the tumbler to take off the bezel, to do that is insert the key and turn it counterclockwise (accessory) and insert a small piece of wire in the very small hole next to the key and pull the tumbler out. I don't know what year your truck is, they vary the newer they get.
hope this helps
[B]67 Chevy truck stepside small back window
96 Dodge Indyram
74 Dart Sport
96 Neon
67chevytrk is offline   Reply With Quote
Old 01-10-2006, 06:23 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: quick ?
All the 67 - 72s were like that... except, I've never heard of a 67 with an acc position.... heck, most of the 68's I've seen don't have it either.
Old 01-10-2006, 11:35 AM   #4
wibilly
wibilly's Avatar
Re: quick ?
thanks i thought there must be a little trick to it
Old 01-10-2006, 07:15 PM   #5
wibilly
wibilly's Avatar
Re: quick ?
been trying to get that tumbeler out. not having any luck key in acc posistion wire in small hole feel spring tension on wire but no luck
Old 01-10-2006, 07:21 PM   #6
john
member #16
john's Avatar
Re: quick ?
Okay when you feel the spring tension turn a little more to the acc position and pull. It should come out. John
john is offline   Reply With Quote
Old 01-11-2006, 12:08 AM   #7
eric67m
eric67m's Avatar
Re: quick ?
My 67 has an accessory position to the left of off. All it does is slightly turn on the red generator light and drain the battery. My only accessory would be the fan and radio and they do not work in this position.
Is a dead battery considered an accessory?
eric67m is offline   Reply With Quote
Old 01-11-2006, 12:11 AM   #8
northcountry67
northcountry67's Avatar
Re: quick ?
I didn't have the key for my 67, so I just held the back with visegrips and kept turning until it broke. I needed a new one anyway.
northcountry67 is offline   Reply With Quote
Old 01-11-2006, 12:35 AM   #9
wibilly
wibilly's Avatar
Re: quick ?
i finialy got it but i had to pull the wire out after turning it just past acc then she came i was ready to get a BFH or air chisel you know what they say,[if it jams force it, if it breaks it needed replacing anyways]
Old 01-12-2006, 08:09 PM   #10
67chevytrk
Damn I'm broke
67chevytrk's Avatar
Re: quick ?
When I turn mine to accessory the fan motor for the heat/ac works, I don't have my radio hooked up, you couldn't hear it over the engine so it didn't do much good....
96 Dodge Indyram
74 Dart Sport
96 Neon
