Active Member
![]() Join Date: Feb 2000
s-10 frame swap q's
Hey guys
I/m anxious to do another 47-53 pickup, but I want to try the s-10 frame swap this time- Which frame do I look for? Use original frame mounts? What all is involved? All replies are welcome- anything at all Thanks! Curbie
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
![]() Join Date: Apr 2005
Re: s-10 frame swap q's
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Active Member
Thanks for the reply
That is one great article. I may rethink this project and do another Musatng II front end. That truck you have for sale makes me wish I had 40 grand Curbie
![]() Join Date: Sep 2005
Here's some more info:
http://www.jalopyjournal.com/forum/s...491&&showall=1 http://www.jalopyjournal.com/forum/s...422&&showall=1 http://www.ad-engineering.com/ http://www.usbodysource.com/install%2047%20chevy.htm I've got an 82 S10 std cab long bed that I'm going to do this swap with. I hope to have it on the road by May. |
Active Member
Hey Orange
Thanks for the reply. I printed eveything out so that I can read it tonite at home. I'll bet the 4wd frames are a little harder to come by. I like the kit idea. I just won a '52 on ebay that has acamaro front clip. I'll have to see how well it was done,if it doesn't look right, I'll just keep the chopped cab and set it on an s-10 frame. Thanks again for the help!
Active Member
Does anyone know anything about Advance Design Engineering and their s10 frame kits-see Orange52's post above.
The kit looks like somehing that would save me a lot of time- the problem is that I can't get a response from them, sent two emails, checked reverse directory, etc. They seem like ghosts. Has anyone actually made contact with them, or know anymore about them?Thanks!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi Last edited by Curbstone Mech; 02-16-2006 at 07:18 PM. |
Looks like a cool kit. I would like a little more information, also.
Rob
Active Member
I ordered the kit on Monday. They sent me 10 pages of pictured directions. Looks pretty simple. I'll update the progress if anyone is interested.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi Last edited by Curbstone Mech; 02-21-2006 at 10:50 AM. |
![]() Join Date: May 2004
I'm interested. I have a '53 Burb (hence the name)
#10 | |
im interested in this kit as well. im doing the s-10 frame swap and the kit seems like its a real time saver. my only problem is that im wondering if it is worth the money. if anyone has this kit i would be interested to know what they think about it.
Active Member
I'll try to make a file from the email of directions and post it here tomorrow, I'm not very good at that tho.
It will be a little while until I get to working on this project- I just had total knee replacement surgery Curbie
#13 |
Knuckle basher
Im doing a s-10 frame for my 52. Im using an 84 extended cab/short box. In the process of mounting a 76 camero rear diff into the rear then will be shorting the frame about 7 inches. Going to undo the factory welds where the front clip meets the frame and shortin it there,slide the frame back in making sure its all true and then button her back up. Will let you know how it goes when finished and post pics.
Only the good die young; I'll live forever. 2002 chevy venture 1952 chevy 5 window pickup 1983 v65 magna |
#14 |
If you need s-10 frames..2wd or 4x4 look me up...i have some and more coming in all the time...Thanks,Erick
Western N.C. 28705 |
#15 |
Whats wrong with your stock frame......most s-10 deal look pretty crappy when done. Too narrow in the front. Mounting everthing is a night mare. Stang II or TCI is a 1 day job. That kits looks crummy when done.Stick with your stock frame
The original PHAT! |
#16 |
SIX BANGER
I want to get a s10 frame and try it i know my is good on the way to be done but i just don't like orig.
http://www.cardomain.com/ride/2597018(NN) 1979 chevy truck swb 454 w turbo400 with buckets 1977 chevy truck swb soon to be 454 1976 chevy dually 454 1969 chevy truck six shooter |
#17 | |
Any luck getting the pictures to post? Could you forward the email directions to me?
Thanks, Hause Pmmerritt@sbcglobal.net Quote:
#18 |
Active Member
Sorry but I havn't started the project yet, so i don't have any pics to post.
I can send a you the file of the instructions today Curbie
#19 |
I'll beat this horse too. If you don't like the way the S10 conversion sits or looks or you just don't have about $1500 to $2000 to throw away, then why don't you just go buy a front saddle for a '73-'87 C10 and roll it under your truck and bolt it up? Worked great for mine and I got everything done in about 2 days and for a whopping total of $300 including the brake booster, master cylinder and pedal assembly.
P.S. Been under my truck now for about 5 years. Only thing I'll change is buy some lowering springs and take out the set I cut down. Oh and the 2 days was coming home after work and working on the truck 2 days.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis Support our troops, stand behind 'em or get in front of 'em. What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance? Last edited by winchster; 07-25-2006 at 05:13 PM. |
#20 |
how did that bolt right up? how much did you have to fab to get that to work?
#21 |
Yes, winchster, I've very interested in what you just said as well. Thanks in advance for any more info.
#22 |
All you have to do is remove all the existing suspension. Have some spacer plates made, should be about 1/2 inch per side. Measure, measure, measure. You will have to also space the steering box, line up your centerline and bolt the saddle to your frame the same way it unbolted from the donor frame. Once you have bolted everything up recheck all your bolts, I used grade 8 bolts. I also had previously added a 350 to my truck so I had motor mounts already welded to the frame. I think, not sure, that you can use the mounts that are on the saddle, this will however put your engine extremely low in the truck. I wouldn't suggest it. Anyway, if I get a chance and anyone is truly interested I can take some pics of my application. Any other questions just let me know and I will happily share my experience.
I found a website that has reposted the original magazine article that I found the idea from 5 years ago. It is http://home.cinci.rr.com/jeffreytom/pg4a.html Just so you know, there are many detractors to this setup. I myself love it, it was inexpensive and it works. I owned a mustange II and I wouldn't want to have the brakes on that car trying to stop my truck. Just a personal opinion.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis Support our troops, stand behind 'em or get in front of 'em. What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance? |
#23 |
Active Member
I think there are several of us that would like to see your pics. I know I would .
#24 |
I would definitely like to see some good pics on what you did
#25 |
My dad did that on his truck originally but has since cut it off and gone with an after market setup. The only thing he didn't like about it was it stuck the wheels out futher that he wanted them. I can't remember how we had the motor in there though....I think we had some plates welded to the frame and to the crossmember that the motor mounts bolted to. Good luck guys.
Bernie |
