Old 01-10-2006, 09:34 PM   #1
Premium72
Premium72's Avatar
Exclamation A ton of progress and some more QUESTIONS..PIX
well got the whole truck put togeather pretty much. im off work almost all this week. so this baby is gettn goin for sure. all i needed was my new tail lights and they came in when i was finished primeing and goin for dinner. so they got bolted on. now the problem is gettn them to work. what color are the wires that hook into the switch under that dash for the brakes and what other wires should be hooked up?. you can see below in the pics how i wires it at the light. are there any grounds that should be grounde for the rear lites other than the ones for the blinkers? any body got any input to get these things workn. they look slick. but theyd look better if they would lite up!!.. HELP!!.. its gettn there for sure now. thanx enjoy the pix. peace. w.
Premium72 is offline   Reply With Quote
Old 01-10-2006, 10:22 PM   #2
RICHARD MORGAN
Re: A ton of progress and some more QUESTIONS..PIX
WoW !! Looks great..Did you use any aftermarket sheetmetal or did you use the orginal?
RICHARD MORGAN is offline   Reply With Quote
Old 01-10-2006, 10:26 PM   #3
Premium72
Premium72's Avatar
all original except one of my tail gates. i have the smoothed out one im going to either do some letters on or some sort of air brushing..I NEED HELP WITH MY LITES!!
Old 01-10-2006, 10:47 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
If you go to the FAQ section, there is a post in there with a link to the schematic for our trucks. I can't remember what color, oh, hold on a minute...Ok, from the left rear light, you have brown and yellow, black is ground at the light. For the right rear, you have dark green and brown, black is ground again. Both of those run up to the plug on the firewall. Let me know if you need any other colors. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-10-2006, 11:27 PM   #5
Premium72
Premium72's Avatar
i need to know the color of the wires in the truck that hook to the switch for the brake and what other wires need to be hooked up for the running lights to come on. thanx ill peep the FAQ
Old 01-11-2006, 08:20 PM   #6
Premium72
Premium72's Avatar
well got the lites to work. but now no brake light. must be a grounding issue. well see. no input?
Old 01-11-2006, 08:25 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-11-2006, 09:59 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
99% chance of it NOT being a ground.
Do your turn signals work?
If the 4 way flashers work, turn them on, and hit the brake pedal, do the 4 ways stay on continuasly, or do they keep on blinking?
Old 01-11-2006, 10:47 PM   #9
matthufham
she's a beaut!
matthufham is offline   Reply With Quote
Old 01-11-2006, 11:11 PM   #10
5150
C10 Club Tennessee
5150's Avatar
Check out this thread. I have those same tail lights and had the same problem. Maybe this will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=173853
http://67-72chevytrucks.com/vboard/s...d.php?t=173126
http://67-72chevytrucks.com/vboard/s...d.php?t=172821
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-11-2006, 11:53 PM   #11
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
If you need a wiring diagram click on the link in my signature. Just finished them today.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-12-2006, 01:16 AM   #12
pjmoreland
pjmoreland's Avatar
You should have an orange wire and a white wire that plug into the brake light switch. The "C" shaped connector on your steering column must also be plugged in to the dash harness, otherwise your brake lights won't work. A worn out turn signal switch assembly in the steering column seems to be a common cause of brake light problems.
pjmoreland is offline   Reply With Quote
Old 01-12-2006, 11:47 AM   #13
jay-dawg
chevelito
jay-dawg's Avatar
nice...what kind of lights are those?
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 01-12-2006, 07:05 PM   #14
Premium72
Premium72's Avatar
the tail lights are from brothers. 54-59 lights i believe. look great. got the tail lights to come on. stay on..no brake lites. was a grounding issue that ill have to get str8. they look awesome. got more pix comen ive done some cleaning and some detailing lookn good now fellas.
