Old 01-10-2006, 09:49 PM   #1
SanitysBane
Lowered BBC, and Frame off-ers
This truck project is going to drive me further over the edge of sanity...anyways I have a couple of questions, first off, I plan on dropping the front of my truck 3-4inches, well already from time to time when I hit a bump in the road the bottom of the collectors on my headers hit. I think I remember something about someone running a pair of car headers, like maybe from a chevelle? Does anyone know about this or can point me in the right direction?
Question 2-I am wanting to replace the leaf spring bushings, How do you do this? I got a propane tourch and a press, any pointers? And what about the A-arm bushings? Should I replace them now or just not worry about it?
Thanks for any help guys.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-10-2006, 11:06 PM   #2
stepside454
stepside454's Avatar
Re: Lowered BBC, and Frame off-ers
I have heard of people runnin Chevelle headers.Ive got Sanderson shortys on my 454 cause the full length headers where draggin
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 01-10-2006, 11:31 PM   #3
f.monroe
f.monroe's Avatar
If it a big block , a set of Hooker Competition (NOT SUPER COMPS)headers for a 68-72 Chevelle or a 70 -74 Camaro will do what you want (same part number ). They have 2 inch primaries and 3.5 inch collectors I think and fit just about level with the frame rails . You will have to trim the driver side frame rail on top to clear one of the tubes . A friend ran these on his truck with good results and the headers are big enough to let a nice BB breathe . His truck was an 82 SWB and I dont ever remember them dragging . I have seen the same application used for small blocks also but I dont know what trimming , if any , is required . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 01-11-2006, 12:13 AM   #4
SanitysBane
Thanks a ton guys! Hmm...Dad has a 68-72 chevelle with a BBC...I may need to borrow his headers for mockup...
'88 K5 Blazer
Old 01-11-2006, 11:29 PM   #5
f.monroe
f.monroe's Avatar
Someone on this board is running those headers but I dont remember exactly who . Maybe AIRMALE (Sp?) . You might search the board . There was a discussion about them around 6 months ago . Frank
Old 01-12-2006, 12:51 AM   #6
SanitysBane
Thanks, anyone know about the leaf spring bushings? I know some one around here has changed them before.
'88 K5 Blazer
Old 01-12-2006, 02:01 AM   #7
Russell
Professional Grade
Russell's Avatar
Thats a sucky job David!
Gotta burn the rubber outta the end of them with a torch, then scrape the rest out
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-12-2006, 12:49 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I linked pictures to the Sanderson headers I am using on my truck in this post:
http://67-72chevytrucks.com/vboard/s...d.php?t=185391
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-12-2006, 06:12 PM   #9
stepside454
Chris...very nice, same ones I have on mine.
Old 01-12-2006, 08:12 PM   #10
AirMale
AirMale's Avatar
The Hooker comps, NOT SUPERCOMPS work. I believe it's part number #2455. 2"primaries and 3 1/2" collectors full length and tuck up between the frame.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 01-15-2006, 06:23 PM   #11
SanitysBane
Thanks guys, does anyone have any pictures of were on the frame you need to notch?
'88 K5 Blazer
Old 01-15-2006, 08:31 PM   #12
f.monroe
f.monroe's Avatar
My friends notch was on the top of the frame where the tube comes down from cylinder 7 . Airmales doesnt look notched in the pic so maybe it isnt necessary . It was a very small notch and my friend may have just thought he needed to notch it . Frank
Old 01-16-2006, 01:30 PM   #13
SanitysBane
Awesome, thanks a ton for the help guys.
'88 K5 Blazer
Old 01-17-2006, 12:09 PM   #14
Captkaos
Captkaos's Avatar
The sandersons on mine don't need a notch.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
