Old 01-11-2006, 09:20 PM   #1
MSL
MSL's Avatar
Need help on swap
Hello i have some questions for you folks i just picked this 86 Blazer up for $445 and it is in pretty good shape except the motor is blown. My questions are i am wanting to do a engine swap from a 6.2 diesel to a gas 454BB. What i need to know is can it be done.? what things do i need to do the swap? Any help would be much appreciated.
MSL is offline   Reply With Quote
Old 01-12-2006, 07:00 PM   #2
MSL
MSL's Avatar
Re: Need help on swap
Any help would be appreciated
Old 01-12-2006, 07:47 PM   #3
Jonboy
Slots go on anything!
The trans will probably work just fine. The engine mounts should work as well, but may beed to be moved. If you could find the fuel system and engine wiring harness out of a gas truck, you would be set.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-13-2006, 10:51 PM   #4
MSL
MSL's Avatar
Thanks for the info i will look into it. and see what i got.
Old 01-14-2006, 06:16 PM   #5
kevinr1970
I think the converter and the modualtor (or solenoid) is different from the deisel to gas. I thinks its still usable but not ideal.
Best bet would be to find a gas truck and get all the parts you need.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-15-2006, 01:29 AM   #6
carl609
carl609's Avatar
I did a similar swap, but used a small block. It bolted right in, the exhaust even bolted up. I drained the fuel tank as best as I could and then filled it to the top with gas. A little bit of diesel mixed in will just cause it to smoke a little until you burn thru it. I had some headaches getting hoses to work, so I ended up cutting them and putting metal pipe in the middle to make them work. All you need is the alternator wiring and a keyed hot for the distributor. I capped the ends of everything and wire tied them out of the way. I am not sure about the convertor being different but you will want to change the vacuum modulator. Good luck
carl609 is offline   Reply With Quote
Old 01-15-2006, 01:52 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Diesel converter has a lower stall than a gas converter...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-16-2006, 11:32 AM   #8
MSL
MSL's Avatar
Thanks for all the help guys its going to be one fun project.
