01-11-2006, 09:54 PM | #1 |
Addicted to Chevy
2 piece or 1 piece driveshaft
I have a 74 short step and i am a a position where i can either replace my carrier bearing or just throw up a new single piece driveshaft. does anyone have any suggestions or experience with this matter? what are the pros and cons of each?
i may also be looking for a one piece that is approx 66 1/2" from the middle of the front to the mid of the rear u joints if anyone has one available |
01-11-2006, 10:51 PM | #2 |
Re: 2 piece or 1 piece driveshaft
I replaced my two piece with a one piece. You can steal one from a older van or suburban. You woill probably have to get it shortened though. Make sure they balance it though. If you have a two piece the driveline angles may not match up if you switch to a one piece though. Just some thoughts.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
01-12-2006, 03:02 AM | #3 |
Right turn Clyde
Cost is much easier to have a longer driveshaft cut down and balanced. To have one longer they don't like doing so and there you are with a custom driveshaft bill $$$. One piece driveshaft = no maintenance aside from u-joints vs two piece with the carrier barring maintenance plus u-joints.
I would go with a one piece driveshaft being you have a swb. It gets harder to do that with lwb trucks being pretty long and pinion angles. goto http://www.Car-Parts.com that should let you search salvage yards in your area. They should have a driveshaft for you truck.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
01-12-2006, 08:17 PM | #4 |
I have one available with a Turbo-400 slip yoke. $50 plus the ride. The yoke alone was $65
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
01-17-2006, 12:04 PM | #5 |
what year trucks came with a 2 peice because im lookin to get ride of a 1 peice for a 2 peice because im baggin mine and i hate the way 1 peice has to be set just right
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
