01-12-2006, 02:04 AM | #1 |
6 to five
doing frame up on 65 sort bed fleet side. realy like too keep stock rear end . what 5 lug axles will slide in . also will 92 s10 booster master and pp valve work . have all ready got 85 c 10 front disc parts/power steer gear box and pump 85 alt 327 sagonow 4 speed and s-10 stuff ho and what tilt colum will work s10 or no
russ 65 short box fleet side 94 s-10 blazer 88 chevy bretta gt my sons a train nut |
01-12-2006, 08:16 AM | #2 |
Re: 6 to five
Here is probally the cheapest solution
http://www.classicperform.com/Store/...ruck/CP4R5.htm http://www.classicperform.com/6092ch...20Brake%20Kits
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 01-12-2006 at 08:17 AM. |
01-12-2006, 10:32 PM | #3 |
Re: 6 to five
The other option would be new axles with the 5x5 bolt pattern. One of my trucks that I am using the parts off of, the PO said he put 70 5 lug axles in the 65 housing. He said 70 disc only had the narrower rear with 5 lug. I looked at it and the axles don't stick out like when I tried 71 and up 5 lug axles in my 65 Burb. Again that's what he said so I don't know for sure but the work fine in my 65 swb, Except for the bent frame I discovered today!
Steve |
01-13-2006, 01:18 AM | #4 |
Re: 6 to five
thanks for the imfo steve i have afriend that should have a 70sorry too hear about what you fond out to day my truck just about striped and ready to start sand blasting
russ 65 short box fleet side 94 s-10 blazer 88 chevy bretta gt my sons a train nut Last edited by domino52761; 01-13-2006 at 01:24 AM. |
01-13-2006, 12:25 PM | #5 |
Re: 6 to five
70's were 6 bolt. 71 up were disk.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-13-2006, 02:00 PM | #6 |
Re: 6 to five
Any competent machine shop should be able to take your original 6-lug axles, weld up the holes and redrill them for the 5-lug pattern. Should cost less than $100 depending on your area.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-13-2006, 02:50 PM | #7 |
Re: 6 to five
I have a 220 ark welder. I should bee able to weld in holes and take a 5 on 5 axel and vise grip them to gether and redrill my 65 axels for 0$ you think it work . I like to tinker any way. OR should i not chanse fing it up
01-13-2006, 02:52 PM | #8 |
Re: 6 to five
agree with smbrouss70 ----but don't bother welding the holes. center 5 so that it only interferes with 1 of the 6 holes and only weld at that spot. The weld is hard to machine and gains little. Flanges have to be turned down for the smaller drum center.
