Top of door jam
Hey guys, need some help here. Since my buddy and I stripped my 69 down to bare metal I have a bit of a problem. I did not strip the upper parts of the door jams, my buddy did, and I do not know what they are supposed to look like. You know, right in the middle, there looks like they did not have enough metal to connect the front to the rear so they bridged it, then filled it with body seam sealer or something. Can you guys post some pics so I know how to make it look. The bigger and clearer the better.
Right here where the door post goes through between the part in question. ![]() Is it supposed to be smooth there or what? If not, has anyone made it smooth through there? Mike |
Re: Top of door jam
I just looked at mine, and as far as I can tell it is still stock. Those gaps are not hidden, just a little bit of filler, but still obvious. i will try and get some pics when it is light out.
Re: Top of door jam
it's supposed to look like that yes.
Re: Top of door jam
You should have seam sealer in there. Not alot just enought to seal the gaps.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
