Old 01-12-2006, 10:44 AM   #1
TrainD5115
North Coast, baby!
TrainD5115's Avatar
vacuum line connectors?
Does anyone know where one might find replacement connectors that go on the end of multiple vacuum lines to a vacuum switch and to the purge canisters? I have a serious dry rot problem with a few of mine.
One other thing. What is the correct placement of the vacuum lines for the air cleaner assembly? Does the line from the carb go on the fitting closest to the inside or the outside of the air cleaner? Thanks.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 01-13-2006, 07:43 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: vacuum line connectors?
You can get some from the junk yard or the auto parts store has the help line products just take the one fitting you need with you to match it up if they dont have it in stock they can look it up in the book and order it for you.
www.autozone.com go to repair info for the vaccum line diagrams to see the correct line routing.
Good luck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-13-2006, 12:33 PM   #3
TrainD5115
North Coast, baby!
TrainD5115's Avatar
I was at Autozone the other day and they didn't say they had anythng like that. I don't need a diagram, the original plumbing is there, some of it is just in bad shape because it is 27 years old.
Brad
79 Scottsdale C20
350/350
3.73's
