01-12-2006, 11:25 AM | #1 |
Vintage Evil
Those who have Hedman Hedders I have a ?
I installed my new hedmans last night. The issue is that the driver side header is hitting the back of the lower A arm. I mean it bolts up fine but it is actually touching the a arm. Anyone else have this issue? Before i get flamed i will take some pics tonight.
Thanks |
01-12-2006, 11:29 AM | #2 |
Re: Those who have Hedman Hedders I have a ?
There is a younger guy here that had that same problem.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-12-2006, 12:19 PM | #3 |
I had a similar problem, I checked the A-frame for alignment (in the U-bolts) then I loosened them up (the U-bolts) and slid the A-frame forwand a 1/2" and it cleared beautifully. I went through three or four different headers to find that I liked the Hooker Coms and they fit the best, but not perfect.
01-12-2006, 12:36 PM | #4 |
Rolled on Paint Club
I have Headmans on a small block with no problems.
Bob |
01-12-2006, 03:46 PM | #5 |
This is good to know! I'm just getting ready to order some headers for my sb 67 and was wondering which brand fits the best.
CoolRide |
01-12-2006, 04:23 PM | #6 |
Vintage Evil
the fit is beautiful other than this issue. And hopefully i can slide it forward like it says in one of the above posts
01-12-2006, 04:45 PM | #7 |
The LuvShack Garage
I have Hedman ELITE Headers on my 4wd Blazer, Perfect fit
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-12-2006, 05:56 PM | #8 |
I too have hedmen elites on a 71, its a good fit. I did grind into the frame approx 1/8" on both sides around one of the tubes (cant remember which) just to make sure the tubes dont rub the frame. Its close to the lower a-arm on one side as well, but clears without issues. This is a 2wd w/sbc350 in stock position.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich Last edited by BubbaGreen; 01-12-2006 at 05:56 PM. |
01-12-2006, 06:07 PM | #9 |
Dork For Days
Not to take over the thread, but anyone know if big blocks have the same issues? I've heard alot about the SB issues, but little about BB ones.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
01-12-2006, 06:47 PM | #10 |
You cant slide the A arm anywhere. It has a alignment pin in the crossmember and it has to stay where it is. Unless it's not set in correctly now but I dont think that's possible.
01-12-2006, 09:24 PM | #11 |
I have hedman's on my truck.And it rubs the passenger side frame.
Also when I ordered them I ordered them for a manual trans.And they sent me the auto one's.So they rubbed the z-bar.I had to use a BFH to get them to fit. Last edited by RPMkid; 01-12-2006 at 09:25 PM. |
01-12-2006, 09:46 PM | #12 |
Had the same problem. Replaced the tranny mount and it straightened everything out.
01-12-2006, 10:13 PM | #13 |
Could this have anything to do with the truck being lowered? Or is it lowered?
JRB Does Doug Thorley Make headers for these old trucks? I know there expensive but I dont think I have ever heard a bad thing about Doug's except how much they cost. |
01-12-2006, 10:27 PM | #14 | |
01-12-2006, 10:28 PM | #15 |
Yes, Thorley has a Tri-Y header for the 67-72's I'm also considering Stan's Headers which are a Tri-Y design and only a few bucks more but the flange doesn't have the welded O-ring design, they're machined flat and Stan claims the welded O-ring causes leaks. Doug Thorley used to work for Stan's Headers.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
01-12-2006, 11:36 PM | #16 |
do the thorleys turn blue at all? Being nickle and chrome just think they will discolor quickly not sure tho.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
01-13-2006, 12:00 AM | #17 |
My uncle has a set of Doug Thorleys on his 77 4x4 BB.
They look crappy after a few years it's a corrosion protection coating and there was no warranty on it. The shop made him aware of that before the purchase. They did turn blue and rusty after a few years sitting on the truck outside. They are a really thick tube think 14 gauge ? That's why he bought them not for long lasting looks. They tend to rot from the inside out.
01-13-2006, 02:17 AM | #18 |
Active Member
For the BB guys...has anyone tried sanderson headers? Good or bad comments would be great. I am getting ready to swap out my small block for a 454/TH400 and I need to decide which headers will work. By the way...I'd like a 3/4 length header for ground clearance being that I want to bag this thing someday. Also, it sounds like the motor mounts can be an issue. I was looking at the set performance online offers.
http://www.performanceonline.com/sto...cat=455&page=1 Thanks Kevin
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
01-13-2006, 05:15 AM | #19 |
I have Hedmans on the 350 in my '71 Jimmy [K/1500]. They were a tight fit, but I did have to joggle the ears on the Z-bar to make the end of the lower clutch rod miss one of the downtubes. The other issue is that you have to completely pull off the passenger side "hedder" if you have to R&R the starter. Outside of the occasional tightening of the bolts on the exhaust plate to eliminate leaks -- common to any headers -- they have worked well for 7 years in this truck.
01-13-2006, 08:57 AM | #20 | |
blood type; Retumbo
I have the regular Hedmanns on my lowered 68 using original arms with '80 spindles. I think my engine is in correct. I measured another 2wd just to make sure. no problems at all. Last edited by 68C15; 01-13-2006 at 08:57 AM. |
01-13-2006, 02:12 PM | #21 |
DON'T TREAD ON ME
I installed Hedmans on my lowered '70 350 4-speed and they fit with out any problems.
I now have Hooker Comps on the same truck and they fit just as good or maybe a little bit better.
Old Yeller |
06-21-2006, 03:31 PM | #22 |
~one mean a$$ truck~
I have a set of headers that will not fit. they are hitting the frame on the driver side, and will not move anymore.. I am not sure what brand they are tho... mine is 71 fleet
06-21-2006, 03:57 PM | #23 | |
The LuvShack Garage
mounts are USED, then they might rub, I had that problem on my old 67, I thought it was the headers, turned out to be a squished motor mount
06-21-2006, 05:08 PM | #24 |
I had to indent the tube 1/4" to clear the frame......
1997 GMC Sierra Ext 1965 Mustang |
06-21-2006, 07:33 PM | #25 |
I have heddman elite headers on my SBC-350, with new motor mounts...the pass side was actually the side that had clearance issues. I used a die grinder to remove a smooth arc out of the frame to make the clearance. At the deepest point, maybe an 1/8" inch was removed. But definetly check those motor mounts as stated above.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
