My slip joint front shaft is shot. Driveline shop says its the wrong length. I measured it at 26-27 inches from center of front uni bearing to back of flange. Which looks appropriate installed - about 1/2 to 3/4 inch of showing slip wear. That seems right. I'm trying to replace it, they want too much for their rebuilt one and wont repair mine - after saying they would for $50.
Would any of you know what the correct length for this should be? This is on my stock 1980 K10 long bed, 350 engine SM465/NP205 Trans & Case. Any help would be appreciated. It's gonna snow again soon. Thanks! - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Re: Front Shaft
are they trying to rip you off? saying they can fix..then say no its wrong size you need a whole new one? go to another place and see what they say.
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
Re: Front Shaft
Well I found one at the junkyard. Too long, so I got the sawzall and air grinder and cut 6 inches off and cleaned up the weld hub. Now I'm looking for a weld shop to double or triple pass this at lunch - on the cheap, of course. Then I'll replace the uni's, lube it up and be off again!
I gotta get me a welder! - Dave
