Largest tire without a lift?
I have a set of BFG AT sitting in my garage that used to be on my Wrangler. However the Chevy has the standard 30" tire and the ones I want to put on are almost a 32". How big of a tire can I have before it starts to rub?
1986 C-10 w/ 305 automatic ![]() ![]() |
Re: Largest tire without a lift?
if it is a 4wd, you may be able to get away with 32's. however i have seen some mixed results. my friends stock hight blazer has 33's with no rubbing while some other trucks rub wuth 32's. it really depends on how saggy your springs are
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
I don't know about 32s, but on my 1 ton, 33s rubbed BADLY until I put my lift in. Here's a pic of my truck before the lift kit to give you an indication:
![]() I could only turn the wheel about 1/2 way to full lock before the tires rubbed on flat pavement. Any kind of bump or tilt in the road where I was turning (like into a driveway) made it even worse. Because of this, I doubt 32s would fit, especially on a 1/2 ton which is quite a bit lower than my 1 ton was, especially if your springs are a few years old. |
I had one ton springs from a military CUCV truck in my K10 and stock 1/2 tons in the rear and ran 33x12.5" tires on 15x8" wheels with 3.75" of BSing, no rubbing at all with no sway bar.
The wheels make a big difference also, if you run 10" wide wheels your probably not gonna clear for sure, 15x8s you could probably do it. And it just depends, I probably couldn't of cleared my 33x12.5's with 1/2 ton springs in mine.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
1/2ton 2WD runs 32x11.50s with no rub unless i hit a bump and then it hits the top outter edge just barely and that is now fixed with rolling the fender.. but i agree it depends on how saggy your springs are.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
7000 #'s of american IRON
on my truck (keep in mind 1 ton), i know height wise a 33" could fit easily, but it hhas 6.5" wide tires right now, so i don't know that you can go much more than maybe 33 x 7.5 without problems at full lock..haven't really looked though.. it has 235/85-16's on it right now.
![]() Join Date: Apr 2004
I have seen 40" on a truck with out a lift. all it take is a little cutting.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#8 | |
#9 | |
![]() I'll leave that for the rusted out truck to do.
I guess my question is can I run a 285/75/16 tire on a 2WD 1/2 ton? (no lift)
#11 | |
Gentleman Jim Driver
I have had 2 sets of 32" BFG ATs on my 84 K10. They rub while backing and turning for about 10k miles especially when turning to the right. They rub on the back side of the inner fender. 32's will probably fit but variations in each individual body will make all the difference. I wouldn't even try 33s.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 01-13-2006 at 03:49 PM. |
Done yet?
Yeah I think that the rim makes the biggest difference. I had 33x12.50s with no rubbing on my 76 3/4 and my roomate had the same tires on his saggy 82 f250 with no problem. I will see soon if I can get 36x12.50s with 4" lift and no cutting.
'76 k2500 -- almost done... |
#13 | |
#14 |
33's rubbed on my 81 K5. Put on a 4" rough country lift (very reasonable) on last year. Very satisified. They recommended 6" for 35's but it looks like I have room for bigger tires with the 4". Currently looking for another set of stock rims to setup with the mudders.
Check out rough country when you look at installing your lift. Great support.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch 1995 T10 Blazer 4.3L 4x4 (Son's) 2004 GMC Envoy 4.2L 2WD 2005 GMC Sierra Crew Cab Z71 4x4 5.3L 240 Fun Finder Travel Trailer Harvest, AL 35749 |
#15 | |
Here are some more designators: M1008: Tactical Cargo, 1 ton M1008A1: Tactical Cargo, 1 ton M1009: Tactical Utility, 1/2 ton M1010: Tactical Ambulance, 1 ton M1028: Tactical Shelter Carrier, 1 ton M1028A1: Tactical Shelter Carrier w/ PTO, 1 ton M1031: Tactical Chassis, 1 ton
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#16 |
K5Camper
![]() Join Date: Mar 2004
I ran my K5 with 33x12.50s and no lift without any rubbing. Heres a shot:
![]() 32's should clear without any issue, but as people have said it will depend on the amount of spring sag. I've heard of some that got away with 35's on no lift with minor trimmage to the front and back corners. Here's the big legal disclaimer: TRUCKS MAY DIFFER, INDIVIDUAL RESULTS MAY VARY.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#17 |
Professional Grade
I've got 31s on my K25, and they are too small for the truck. Wanna go with 33s when all is said and done
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#18 |
Right turn Clyde
One thing you also have to do is measure the actual tire size. There is a lot of variances in different tire manufactures. My 31x10.50 (15x8 rims) tires are only 29.5 inches tall and that was when they were brand new installed. Rim width will also effect overall tire height along with how the tires wear on them.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#19 | |
Edit: I see the correction has already been made.... whoops.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. Last edited by Destructo; 01-13-2006 at 10:52 PM. |
#20 |
A sorta cheap way to get a little more "lift" would be to replace all the cab/body mounts with Polyurethane/Polygraphite.
32x11½" 15's on a 15x8 with 4" BS should work on a ½ton 2wd.. |
#21 |
Now my only question is where can I get a set of 16" rims with the same bolt pattern. I hear that the WJ Grand Cherokee (1999-2004) have the same 5x5" pattern - is this true or not? Did GM ever make a 5 bolt 16" rim? I know that they have 6 bolt 16" wheels for the 4WD Suburbans and Tahoes. Are there adaptors available?
#22 |
WTB this ad
My old 84 Camorado with 33x12.50 on a 15x8 rally. I slightly rubbed on the tie rod on the driver side. Oh by the way there is no lift on it.
#23 |
here are pics of mine with 32"s... most of youll have seen em already...
#24 | |
Real Projects never die
Yes, they did make a 16x5.5 rim for a 5x5 bolt pattern, ive only got five, and the four best are on my 1977 Heavy half, making its stance like a 3/4 ton (tough looking now) and its got 31s. I did this because my speedo was off by ten, and now its about 4 slow because of my 3.42 rear. If you want, i can get some pics for ya. ive been looking for about 6 months, and my dad has been looking for about 10 years for another set of them. If you happen to find a set, gimme a call. A buddy of ours picked them up at a farm sale.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#25 |
i run a 36"/12.5"/16.5", i think i'm going for something smaller like 32”/10.5/16.5
what do you think guys... |
