Old 07-16-2002, 07:45 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
body work tips anyone?
some time soon gonna try to do rockers, corners, floor pans on the step side, any tips on doin this stuff, Its not gonna be any show truck, just lookin to have it look decent. the bed will prolly be off when I do it, maybe front clip too. its just gonna be a driver planin on flat black...
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 07-17-2002, 06:30 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Arrow
A decent mig welder and most importantly, a spot weld cutter. Other than that, take your time and have fun. It's not bad once you get into it.
Replace the floor braces while your in there. Since your replacing the floor, you can do all the work from the top side.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-17-2002, 09:40 AM   #3
Downtown
Downtown's Avatar
Cool
Make sure when you replace the rockers you do it with the doors on the truck. If you do it without the doors on the truck, it is almost for certain that the rockers won't fit correctly. Tack the rockers in place than remove the doors and finish the job.
72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new
66 Chevy Caprice 2 dr
77 Caprice Estate Wagon
New Palestine, IN
Downtown is offline   Reply With Quote
Old 07-17-2002, 10:26 AM   #4
kxmotox247
kxmotox247's Avatar
Downtown is definately right about having the doors in place.
The rockers add a lot of strength to the cab so removing them without the doors in place will cause the door opening to "flex", and then when you put the door back on, it won't fit or the gaps won't be even.
The same goes for when chopping tops...
A good piece of advice, maybe not neccesary when just replacing rockers, is to reinforce the cab before you cut. You might consider welding the doors in place (in just a couple spots you can cut loose later). If you are also cutting out the floor, you can cross brace the doors and the cab together with some 1" square tubing to hold everything true.
One more tip for you, use a guide coat before you paint. This is what I do before I paint anything. I spray a light colored primer over everything. The I take a can of black laquer and very lightly "fog" the primer with the black. I repeat, very lightly. Then with 600 grit paper, I wet sand everything and take off the black laquer. I know by looking if the black comes off quickly, that's a high spot. I know where my low spots are when it takes a long time to get the black off. Sometimes you will have to go back and re-primer certain areas where you sand through a high spot.
Remember, take your time to do it right. All of that blocking will pay off.
Good luck!
kxmotox247 is offline   Reply With Quote
Old 07-17-2002, 10:37 AM   #5
Cyco Path
Spot Weld Cutter?
What's a spot weld cutter? I'm not familiar with that tool.
Looking for '67 to replace the '68 I sold.
Robertsdale, AL
Cyco Path is offline   Reply With Quote
Old 07-17-2002, 10:49 AM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Here I found one for you.
http://www.autotoolmart.com/cgi-bin/...05102496515.44
Ben
67Fleetsidedream is offline   Reply With Quote
Old 07-17-2002, 10:57 AM   #7
Low69CST
Use plenty of weld-thru primer, seam sealer, and undercoating.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-17-2002, 06:57 PM   #8
Cyco Path
Ben
Danke!
Robertsdale, AL
Old 07-17-2002, 07:42 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
Along with the above tips, I would suggest using on the parts of the patch panels that you need, speciifically the floors and cab corners). There is no sense cutting out good original metal just to make the panel fit. Instead, cut the panel to fit the rust area you cut out of the truck. I made that mistake when replacing my cab corners. Take your time and have fun!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 07-17-2002, 07:46 PM   #10
ebfabman
Guess I've been screwing up for years.........
Replaced many cab corners, rockers, and floors etc, and never braced anything ever.
Most recently on my own truck I replaced left and right front and rear floors, all four cab supports, right and left "A" pillars, right and left "B" pillars, inner and outer rockers (both sides) right and left cab corners, and right and left kick panels all finished with no bondo at all and all done with NO bracing anywhere.
Both original doors with the original hinges fit and open/close perfectly afterward.
Now if you're gonna do some choppin tops, some bracing might help.
Maybe I've just been real lucky........
ebfabman is offline   Reply With Quote
Old 07-17-2002, 11:18 PM   #11
big blue 72
buying a new welder for a beginner...
what should i buy? i will only be able to run 110.
probably just use it for panel work too......
big blue 72 is offline   Reply With Quote
