Old 01-12-2006, 11:01 PM   #1
TreverSlyFox
Question What's with timing the 70s 350s????
Figured it was time to do complete tune-ups on my 71 GMC 1 Ton and the 70 Chevy C-10, both are V-8 350s.
Didn't have a timing light so I crused down to NAPA and bought a Timing light that does more than timing, about $178 $$$ more. Anyway I'm looking over the GMC and I can't find the timing degree pointer, so I grab my trouble light and really start looking. IT'S UNDER THE WATER PUMP !!!!!!!!!!!!!!!
And I mean UNDER, just the "teeth" sticking out, can't see the degrees etched on it. Looked at the 70 C-10 and it's the same, no way to get a timing light on it without sticking your hand into the running fan. Now I'll admit I was a FORD man until lately and only got into the 70s Chevy trucks recently, but this has me stumped. I don't see any way to get a light on the pointer and even if I could I can't see the markings to set it. I must be missing something because it doesn't make any sense NOT to be able to time the engine.
The 71 GMC has HEI ignition with a 4 speed and the 70 C-10 is an automatic with points.
TYIA
TSF
TreverSlyFox is offline   Reply With Quote
Old 01-13-2006, 12:30 AM   #2
carl609
carl609's Avatar
Re: What's with timing the 70s 350s????
if you paid that much for a timing light it should have an advance feature, then all you need to know is where zero is on the pointer. if you have a long water pump you can usually point the light behind it and see the mark.
carl609 is offline   Reply With Quote
Old 01-13-2006, 12:48 AM   #3
Russell
Professional Grade
Russell's Avatar
I usually just get on top of the core suppport, and look straight down behind the water pump. Should be fairly visible from there
If you rub that timing tab, you'll find the degrees etched into it. I've never seen one without.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-13-2006, 01:59 AM   #4
jhow66
jhow66's Avatar
You have late model engines. 70 & 71's had timing tabs at about the 2:00 to 3:00 oclock postion. Might want to check your engine #'s-could be 305's.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-13-2006, 04:22 AM   #5
jimfulco
Later-model engines (mid-'70s) with the 12:00 timing marks came with long water pumps that you could shoot the light down behind. Yours got a short pump?
jimfulco is offline   Reply With Quote
Old 01-13-2006, 09:02 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
they were designed that way for timing ease when there is all the extra stuff mounted on driver side of engine. if you want you can just get a different pointer & after using a TDC stop to find true TDC make a new mark on the balancer.
68C15 is offline   Reply With Quote
