01-12-2006, 11:23 PM | #1 |
Guys with power windows...
do your windows seem slow? I just replaced my driver side motor and it seems to slow down mid way going both up and down. The passenger side does also but I thought this was because it was getting ready to need a new motor as well. I really have nothing to compare it to cause this is the first truck I've had with power. May be switching it to manual.
01-13-2006, 12:53 AM | #2 |
Re: Guys with power windows...
I used Penetrating oil on the main pivot point that the motor turns, and greased up the tracks. Made a HUGE difference
-Jeremy
79 Jimmy slammed AKA James Down |
01-13-2006, 01:43 AM | #3 |
I tried lithiun grease. I can live with it, I was just wodering,,, Thanks
01-13-2006, 01:47 AM | #4 |
Yes typicaly they are pretty slow. making sure your pivots are well lubed and your channels are in good condition helps also. to my knowledge no one has found a great solution to the problem but corect me if im wrong.
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
01-13-2006, 09:00 AM | #5 |
STILL PLAYS WITH TRUX
Thats just the way they are!
Mine are not to bad iv'e seen solwer ones. |
01-13-2006, 07:46 PM | #6 |
Try some armor all or silicone spray on the window felt that the window rides up and down in. It helped on my 85 after I put in new motors.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch 1995 T10 Blazer 4.3L 4x4 (Son's) 2004 GMC Envoy 4.2L 2WD 2005 GMC Sierra Crew Cab Z71 4x4 5.3L 240 Fun Finder Travel Trailer Harvest, AL 35749 |
01-13-2006, 10:47 PM | #7 |
Parts and more parts
Use silicone spray lubricant on the window felt, OR get new felts for the doors. They have a serious tendency to dry out and then get full of dirt and cause dragging.
01-15-2006, 07:06 PM | #8 |
I have no time for this
If the wires in the door jam boot are broken with only a few strands left it will make them slow as well because the electricity does'nt have enough flow to power the window motor Ihad this happen on my 4x4.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
01-15-2006, 11:49 PM | #9 |
Tried the armor all, it helped a little. I'll have to check the wires.
01-17-2006, 02:31 AM | #10 |
Until Seventy Times Seven
I wonder if upgrading the wiring and throwing in a relay at each door would help the power windows...
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
01-17-2006, 03:22 PM | #11 | |
01-19-2006, 01:58 PM | #12 |
I have heard that if you change the plastic gears it can go faster. Not sure if it means go larger or go smaller. Try www.autoloc.com, they sell gears.
I am putting power in this spring. I am going to put the door jam conectors on each side to eliminate wires. That should help. Doug |
01-19-2006, 07:27 PM | #13 |
I'm not sure about the upgrade on the gears, that would be great if it exists. The door jamb connectors will have a setback to them also. They will only work if the door is closed and the contacts on them can get burned or dirty and will need a fair amount of maintenance to ensure they contact right.
