Old 01-13-2006, 12:35 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Drove my project home last nite for inspection
Last nite, I drove the 1967 4x4 white beast home for the first time, and started it in the cold this morning. I noticed lots of things I never had before. Tell me what you think
It has bias-ply knobby tires on right now and has been sitting for some time, so I expect some bumping, and rough ride. What I hadn't quite expected was a lot of what felt like bump-steer. The P/O let me know that it needs tie-rod ends. Could this be the source of the bumpy steering or the tires, or big problems.
I noticed small rust holes under each of the vent opeinings, uncovered more rust in the bed, and rocker panels. I haven't peeled back the rubber mat and sound deadener, but expect to see more rust there. The floor feel solid, but that is not the same as rust free.
The clutch seems to engage all at once. I have lots of pedal travel, but at one point, there doesn't seem to be any slipping, just engaged. I drove my dads 71 k10 for years, and don't remember the clutch acting like this. This morning in the cold, I had a hard time getting it to shift into neutral. I could get it in all 4 gears, and reverse, but when I let the clutch out in neutral, the engine lugged down. Cold gear lube? Transmission problem?
The truck drives fine in 1st (granny) and 2nd, but has a miss, and it is dreadfully noticable in 3rd, and 4th. I expect that I'm just at too low of an RPM, and this amplifies the effects of the miss. Truck has set for 1+ years, so it is possible that I have fowled plug, or bad wire. Just haven't gotten to that yet.
The arrangment is $1000 for a running pickup. The P/O has replaced the mastercylinder, and put in a new starter to get it to the point it is right now. Do you think I'm getting in over my head or thowing my money away? I've told my wife that if I buy the truck, and find it has more that I can fix, I'll put it on e-bay. Do you think I could make my money back?
More pics including build sticker
Thank in advance.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 01-13-2006, 12:44 PM   #2
cheyenne10
cheyenne10's Avatar
Re: Drove my project home last nite for inspection
Looks like you did very well. Truck looks saveable from pics. Also looks like a front and rear 3.73 posi. Your front bumper and grill guard setup is a nice item too. Put a few hundred into it with good overall tune, lube, tires and wheels and it will make you proud. Also lift front end up and do front steering and suspension review. I like the pic with the older owner signing it over. I like them that way, untouched and good history usually.
Keep us posted on progress.
Bob
cheyenne10 is offline   Reply With Quote
Old 01-13-2006, 12:49 PM   #3
thejoker
thejoker's Avatar
Looks like a decent deal. Body is straight and only minor rust. I suspect a considerable amount of rust in the vent area, which is common. The bumpy ride could be numerous things but I would suspect the tie rod ends in conjunction with the tires. You better be prepared to spend more than probably what you have in mind, maybe even not consider the cost. I think you could make your money back on Ebay pretty easily. Of course this just my opinion.
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey****
68' C10 Short Step (rebuilding as we speak)
72' Custom Camper (wrecked, parting out)
79' C10 Fleet (rough, parting out)
97' C1500 Short Step Custom (DD)
97' Kawaski VN800a Customized
99' Z71 Silverado
04' Suzuki Volusia
thejoker is offline   Reply With Quote
Old 01-13-2006, 02:48 PM   #4
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
$1000 for a running 4x4 truck is a good deal, up here in the northeast we have to inspect a truck to make sure how much rust it has, many truck around here do have a lot of rust and they stilll sell for a lot of money, I've found out that once you start putting money in a truck and try to sell it is hard to get most of your money back.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 01-13-2006, 03:27 PM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
looks like a great deal to me it would go for lots more here in east tn
tnblazerk5 is offline   Reply With Quote
Old 01-13-2006, 06:53 PM   #6
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
The engine miss in higher gear @ higher speeds is probably a gas and or filter issue.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 01-13-2006, 07:31 PM   #7
cdowns
cdowns's Avatar
as far as the miss is concerned , a good tune up might solve that // new plugs,points ,condensor cap plugwires air and gas filters then set the timing also inspect for dry cracked vaccume hoses while doing the tuneup you can also dump a couple of cans of fuel system injector cleaner into the gas tank while you're at it
Old 01-13-2006, 07:50 PM   #8
krue
Designated A-hole!
krue's Avatar
I'd tune it up, tires and tie rods, then see what you think. Lot easier to sell it if it doesn't have the easy to fix problems.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-13-2006, 07:59 PM   #9
Novaguy73
Novaguy73's Avatar
I think you did well. I spent 1000 on mine and its a running driving 72 C-10. No 4x4 but it has AC PS and disc brakes. The big difference my floors, supports, cab corners, and rockers are G for GONE!! I think you did well though. I wouldnty worry about it.
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere...
-72' C10 350 Auto 12 bolt, runs 19's?? drives to work!
Novaguy73 is offline   Reply With Quote
Old 01-13-2006, 11:16 PM   #10
Premium72
Premium72's Avatar
these trucks are more about the spirit than the value. if its worth it to you to tear it apart and see how simple and damn near perfect things were in those days, and to enjoy the process. then YES its worth it. if you dont wana get your hands derty and bust some knuckles then....maybe not..good find. enjoy.!
Premium72 is offline   Reply With Quote
Old 01-14-2006, 01:45 AM   #11
Jetmech727
Sound like a good deal. It being a 4x4 makes it a good pick in my book.
"When cows laugh, does milk come out of their nose?"
Jetmech727 is offline   Reply With Quote
Old 01-14-2006, 03:23 AM   #12
JRB
JRB's Avatar
I know a guy that bought a set of Bias Ply tires that cost him 1200 Dollars and The same day he put them on he took the truck back and had them take them off. I dont think I have heard anything good about them. Expecially in a cold climate.
JRB
JRB is offline   Reply With Quote
