Old 01-13-2006, 07:47 PM   #1
lvscott
cpp new panhard rod
I just installed this on my truck. it seems to me that should solve the problem with it hitting the frame when aired out. it was $109.00 from cpp.
lvscott is offline   Reply With Quote
Old 01-13-2006, 08:00 PM   #2
Shev
Head Peon
Shev's Avatar
Re: cpp new panhard rod
Any chance you've got some bigger pics...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-13-2006, 08:09 PM   #3
lvscott
they are bigger on my computer. i don't know why they turned out this small?
Old 01-13-2006, 08:18 PM   #4
lvscott
mabey these will be better
Old 01-13-2006, 11:16 PM   #5
FnLow69
FnLow69's Avatar
nice but holy big tires batman, those 31's
FnLow69 is offline   Reply With Quote
Old 01-13-2006, 11:50 PM   #6
lvscott
i know, those were the tires that came with it. i just got the axels redrilled. here is a pic with it aired out on 30'' tires. when i get my 20's i'm going to run a 45 or 50 series tires, for ride comfort, which will also be about 30'' too.
Old 01-14-2006, 12:18 AM   #7
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Looks awesome! I have a few questions though:
1. What was hitting before? The adjustable panhard only corrects the rear end from shifting over as you get the truck lower.
2. What bags are you running?
3. Since the adjustable panhard bar you have (super track bar) wraps around the trailing arm on the passenger side and is about 1/4" thick, is there something you put in between the block and the driver side trailing arm to level the rear end out? Otherwise, it would be off by 1/4" to the pass side.
I have the standard adjustable panhard bar and it just uses the stock mounting location. In hindsight, I should have gotten the super track bar like you did.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-14-2006, 12:40 AM   #8
68haywagon
I'm watching you!
Good point. I haven't lowered a vehicle before so I don't know this answer, but is 1/4" noticable?
Also does it bolt up to the stock frame location or is there a new bracket?
Looks like a good project going on there!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 01-14-2006, 01:43 AM   #9
lvscott
1. i noticed before buying my track bar that people were having problems with their track bar hitting their c- notch when aired out and they had to mod them unless they used blocks. this new bar solves that.
2. i am running coinitec bags, 3'' DJM drop spindles, strong arms, cpp c-notch and 2'' blocks.
3. the kit comes with a plate the same thickness as the mounting plate for the opposite side.
the only thing i might change is the c-notch to a step notch. without bump stops i only have about 2'' or 2 1/2'' till i bottom out at ride hight. i want it to sit level, no rake.
Old 01-14-2006, 01:46 AM   #10
lvscott
Mike
yes it does bolt up to the stock location.
and thanks. i am doing a frame off, so i won't be able to drive it for quite a while, but i can't wait till it's done
Old 01-14-2006, 02:50 AM   #11
SCOTI
SCOTI's Avatar
Originally Posted by lvscott
1. i noticed before buying my track bar that people were having problems with their track bar hitting their c- notch when aired out and they had to mod them unless they used blocks. this new bar solves that....
Yep, there are several members that had issues w/the super track bars hitting the frame when dropped low enough (with & w/o blocks from what I remember).
That's a simple bolt on fix. My buddy, n2billet, did a similar plate but fabbed & welded his in. His pics are in the truck section & there's a decent shot of what he fabbed. I wasn't aware that a bolt-in solution was offered. Good info to know.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
