Old 01-14-2006, 12:10 AM   #1
bagged74
its just $$$$$
bagged74's Avatar
67-72 step notch??
anyone know who makes a notch for 67-72 trucks other than the small bolt in one? Im looking for something along the lines of a weld in step notch. any help would be appreciated. Thanks
bagged74 is offline   Reply With Quote
Old 01-14-2006, 12:45 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: 67-72 step notch??
Suicide Doors has a pretty good variety. Or any good shop can fab something up for you.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-14-2006, 02:39 PM   #3
el curioso
el curioso's Avatar
https://www.baganddrag.com/categoryN...?categoryId=10
el curioso is offline   Reply With Quote
Old 01-14-2006, 09:11 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
neither of those places appear to have one that is curved the same as the frame on a coil sprung truck.
Old 01-14-2006, 09:19 PM   #5
67Fleet
67Fleet's Avatar
Doesn't matter. It's a weld in, you can cut and weld it any way you want!
-Bret
Old 01-14-2006, 09:22 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
I understand that. I work in a shop that builds street rods. I can do the fabrication if I wanted to. I was just looking for something that would save me the time/ trouble of building it.
Old 01-15-2006, 02:46 AM   #7
BigShoe24
True Addiction
BigShoe24's Avatar
Bagged74, check out kpcomponents.com they offer a step notch that is tappered as is your frame. I have been looking for the same thing for my own truck. Im not sure how tall it is though. If you find out please let me know.
BigShoe24 is offline   Reply With Quote
Old 01-15-2006, 02:33 PM   #8
a squarecan
I do not know of anyone making a 63-72 specific step notch, but I know a number of people have used the standard 8 piece step notch that Jason along with many others sell and just weld it in. The only down fall to this is that your notch will sit something like this.. \ / Now it is not that drastic and after looking at a few I kinda like the look. I know there is someone on the board that has a 66 long bed he did this way. I have decided I am just going to cut my frame off right behind the first bed mount and make the rest. We will see though cause I may get lazy and just build a notch and weld it in at an angle.
Hope this helps some
Keith
a squarecan is offline   Reply With Quote
Old 01-15-2006, 09:29 PM   #9
Inthuwind
Straight jacket required
Inthuwind's Avatar
I bought a notch from Western Chasis that welds in. It's like they took a short piece of 6 inch steel pipe and cut it in half. I'm cutting my frame to put it in.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 01-15-2006, 09:52 PM   #10
project76
project76's Avatar
As mentioned above
http://www.kpcomponents.com/default.asp?S=503&A=E&PKV=SN-2|0
I have this notch installed, fit was pretty good.
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 01-16-2006, 12:54 AM   #11
BigShoe24
True Addiction
BigShoe24's Avatar
Project76, Was wondering how tall this notch is from kp, Could you possibly measure from the bottom of the original frame to the bottom of the new step notch. Thanks for the help. Just want to make sure that I will have enough room to go low.
Old 01-16-2006, 12:55 AM   #12
bagged74
its just $$$$$
bagged74's Avatar
I think its 8 inches, but i wouldnt swear to it.
Old 01-16-2006, 08:44 AM   #13
project76
project76's Avatar
The notch is 7.5" from the bottom of the factory rail. Not sure if its gonna get me low enough yet or not with my 29" tires. Waiting on some 3" blocks i ordered to come in, since the frame rails and trailing arms are hitting now.
Brandon
