01-14-2006, 05:37 AM | #1 |
Where to get new Junction Block?
The Junction Block that goes on the firewall...I'm going to do that headlight upgrade, and I want to put a new JB on too, because of the electric fan and stuff..where would I get one, and about how much can I expect? Thanks.
01-14-2006, 04:05 PM | #2 |
Re: Where to get new Junction Block?
I'd check around some of the aftermarket catalogs first. Or if you have a good contact at a gm dealership who will take the time to look something older up for you it might be still had thru gm. Since i worked at frieghtliner for 10 years i am going to use something similiar but its a bulhead connector as a hole has to be drilled thru the firewall as i want all my accessory circuits seperate from the oem fuse panel. I'm going to run 3 so i have batt hot - gnd - and ign.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
01-15-2006, 12:57 PM | #3 |
Chevy duty....$2.99.
DW
01-15-2006, 01:52 PM | #4 |
Professional Grade
stock one has something like 12 spare ports in it. Just need to find a source for the crimpable spade connectors it uses...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-16-2006, 10:36 PM | #5 |
You guys are thinking of the wrong part, I think...
This is the little diamond shape thing, on the top of the firewall, has two posts on it, one is BAT and the other goes somewhere into the truck... |
01-16-2006, 11:29 PM | #6 |
Professional Grade
Junkyard 2 - 3 bucks
01-17-2006, 12:44 PM | #7 | |
01-17-2006, 01:51 PM | #8 |
Regular guy
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
01-17-2006, 05:33 PM | #9 | |
