power steering bracket question
i have a 71 with crate motor with header and long water pump. i used all the brackets and pulleys off a 77. i do not like the way the PS bracket bolts to the head. i had to use a wide spacer to accomadate how the bracket is designed (see pictures) Is this a normal stock setup with the stock manifolds? I will be getting new ceramic headers, Im looking for alittle cleaner looking set up for this bracket. thanks
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE Last edited by roadking; 01-14-2006 at 12:26 PM. |
![]() Join Date: Mar 2003
Re: power steering bracket question
That is what is required when running headers, the distance has to made up for the cast iron that is missing. A cleaner setup would be a serpentine set. I just dropped almost 800 for the one I just bought.
there is a different type of bracket that mounts dow lower i will see if i can find my old one. or u could go with a bracket system from march that looks nice and classy
gentry,
do you have a pic. thanks
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
Here's a pic of mine. This is an original setup with short water pump. The pump is a later design, but still works. Also my headers work......
1997 GMC Sierra Ext 1965 Mustang |
I looked on the website of march performance and found these threads there
http://www.marchperf.com/instruction...structions.pdf http://www.marchperf.com/instruction...structions.pdf |
member #16
![]() Join Date: Dec 1999
Heres a long pump bracket. It is basically the same as yours except it bolts on front of head also. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
member #16
wrong pic. John
10/30/19
here is a pic of a 70 p.s. pump w/bracket.It bolts to the 2 front holes on the block and one on the motor mount.
Fight the good fight, finish the race, keep the faith |
