73-87 engine mounts
Whoops, I threw away my 72 mounts instead of the 77s it looks like, so right now for my 72 I’m attempting to line up the pair from the 77. The top mounts line up on the frame rails, and the bottom holes don't line up for the cross member mount. I can drill some holes in the cross member and be done with it right? They’re a 1/2 closer together than they should be but there's plenty of tolerance for that. Also isn’t there a benefit to using later model mounts?
Re: 73-87 engine mounts
Are you installing a small block? If so I have a set you can have. I'm in Ft Worth.
Well dam your hooked up just like that.....
lov this site
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Well the mounts are really not that different. If I remember right the 73-87 style mount will move the motor back to the firewall about a inch. Other then that its cool.
well i hope i don't have firewall issues, the hei looked hard pressed already. i had mounts for a smallblock for both the 72 and 77 so the motor will bolt in no problem.
edit:pics, i think i got an inch to spare, will i need a bigger fan spacer? Last edited by matthufham; 01-14-2006 at 09:48 PM. |
#6 | |
![]() ![]() Join Date: Jul 2002
BTW - I have HEI and there is plenty of room between the firewall and distributor.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-14-2006 at 09:55 PM. |
