Old 01-14-2006, 07:12 PM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Question Restoring Kick Panel Vents???
The rubber around the edge of the kick panel vents in my truck is shot. I can clean up the vents and paint them, but I'd like to have a good seal. Has anyone taken them apart and put some kind of new seal around them? Is there rebuild kit (seals and rivets) that can be bought from a vendor? Or, can you buy new ones?
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 01-14-2006, 07:29 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Restoring Kick Panel Vents???
I know I have seen new seals, but haven't seen the rivets sold with them to replace them. There is also a place on ebay that renews them for like $50. You just send them yours and they replace the seals and powdercoat them for you. Looked like a nice service.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-14-2006, 07:44 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Order the replacement foam from any of the board vendors. Drill out the old rivets, clean and paint the pieces, put the new foam in place and rivet them back together. Not a very big job at all....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-14-2006, 08:30 PM   #4
BubbaGreen
The rivets that are used in the vent kits also fit the vent doors....I purchased the rivets from gmcpauls and the tool that goes with it.
Then I drilled a 3/8" hole in a harbor freight 1/2Ton press to install them without distorting them. Worked perfectly. FYI: if you take them apart, keep them seperated, LH and RH are a little different and if you mix them up without a reference, you might have to do it twice (dont ask me how I know)
Chevyduty sells the foam that is nearly identical to the originals.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
