Help !! Brake Lights
I'M HAVING A PROBLEM WITH MY BRAKE LIGHT SWITCH. WHEN ITS DISCONNECTED ALL MY LIGHTS WORK .WHEN I CONNECT IT THEY DONT. HELP
its all about the +6 inches
When you remove the switch from the pedal, they are supposed to come on. That is in the design.
When you install the switch, you'll see that it is threaded. Screw it in until the little white button is just barely being pushed in my the pedal arm.When you pres the pedal, the button comes out, turning on the lights. |
