Old 01-15-2006, 02:49 PM   #1
Frocky
Big Window / Small Window
My 62 p/u has the BIG rear window, but the cabs roof is pretty well rusted out along the drip rail. I have access to a clean no rust 61 cab with the small rear window. other than the size what is the differnce. Is one more rare than the other, is one more desirable to have.
the new guy
Frocky is offline   Reply With Quote
Old 01-15-2006, 02:51 PM   #2
1969owner
1969owner's Avatar
Re: Big Window / Small Window
i have a 67' cab on my 69', i like the small window without slideing.thatway i feel secure about it not leaking.
1969owner is offline   Reply With Quote
Old 01-15-2006, 06:14 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
From my experience, the big window is preferred by most. It was an added cost option.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-15-2006, 08:15 PM   #4
zenish
you may be able to sell your big window cab to someone for parts.some like to convert to a big window.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 01-15-2006, 11:44 PM   #5
qksilver
All you have to do is cut the sheet metal from the outside to fit the big window. Then remove the inside panel from the big window and install it into the small window cab. I have done it on a truck years ago. Fairly easy and you have all the parts to do it. Drill out the spot welds for the inside panel.
qksilver is offline   Reply With Quote
Old 01-16-2006, 10:55 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
Convert the small window cab to a big window. I'm doing it soon. this link has some info on the conversion
Frizzle Fry is offline   Reply With Quote
Old 01-17-2006, 01:36 AM   #7
Frocky
Thanks guys
Old 01-17-2006, 11:51 AM   #8
Hilandr451
Hilandr451's Avatar
Thanks Frizz, for the press! I didn't have to post anything! cool! In case you don't know Frocky, I'm finishing up a big back window conversion at the moment.-
Got the "new" dash in and I've welded all the "extra" holes in the cab that I don't need. (especially that big round one on the corner just behind the driver's side door handle). I have the first coat of body filler on and I should be ready for primer by Sunday. Before I button everything up though, I'm going to dry fit the big back glass just to be sure everything is going to fit after the conversion. ....measure twice - paint once!
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
