Old 01-15-2006, 04:26 PM   #1
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Re Assembly on Vent window lock? And Fumes in cab??
SO I need a diagram for reassembly of the vent windows...I didnt take them off my buddy did that tinted the windows. ?? Help? thanks!
Also...I have a horrible fumes/ gas smell in the cab when its running. It almost looks smoky in there when you let it idle. What could be causing this??
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-15-2006, 04:55 PM   #2
LOHRTBT
LOHRTBT's Avatar
Re: Re Assembly on Vent window lock? And Fumes in cab??
Problem One solved. Still need assistance on what might be causing the fumes in the cab...its really bad and makes you have a horrible headache.
~Dave~
Old 01-15-2006, 05:02 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Does the exhaust system have any holes in it? Is the blower motor running when it happens?
I dont think it would be the vent window any more than like the window being down would cause.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-15-2006, 06:29 PM   #4
marvxyz1
marvxyz1's Avatar
rust hole around filler tube will cause it.
marvxyz1 is offline   Reply With Quote
Old 01-15-2006, 06:49 PM   #5
LOHRTBT
LOHRTBT's Avatar
No....these are 2 different problems...the windows are fixed. The Gas smell is my concern.
What is the filler tube you are talking about?? its a new exhaust system with dumps...and I never had a problem with my old truck and dumps with smell.
~Dave~
Old 01-15-2006, 07:36 PM   #6
Izzy
Trucker.
Izzy's Avatar
Is the seal around the steering column/firewall in tact? That would be where I'd start.
Izzy is offline   Reply With Quote
Old 01-15-2006, 07:45 PM   #7
LOHRTBT
LOHRTBT's Avatar
I will have to check that out.
Old 01-15-2006, 08:52 PM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Also check the fuel pump for leaking.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-15-2006, 09:05 PM   #9
LOHRTBT
LOHRTBT's Avatar
Ok....So if I move the selector over to OFF and have no vent or heat or air.....NO smell. If I open it, SMELLY TOWN!
Old 01-15-2006, 09:37 PM   #10
79BIG10
79BIG10's Avatar
Maybe a clogged EGR?
Old 01-15-2006, 10:05 PM   #11
MylilBowTie
Right turn Clyde
Its something in the engine bay area, the fan blower is blowing it in the cab. Is there a strong gas smell under the hood without the engine running?
Old 01-16-2006, 12:08 AM   #12
LOHRTBT
LOHRTBT's Avatar
somewhat..but not bad when not running. Hell its got gosh knows how many miles on a stock 305 haha. Has audible valve problems in the exhaust note but it runs fine.
~Dave~
Old 01-16-2006, 02:05 PM   #13
LOHRTBT
LOHRTBT's Avatar
So no one else has this problem?? dang
Old 01-16-2006, 02:41 PM   #14
MylilBowTie
Right turn Clyde
If you really get bored. You could rent a fog machine put in the engine and turn it on with the hood almost closed. Then go in the cab and look where its getting in at. Just an idea Ive run out of everything else unless the cab is pretty rotted someplace.
Old 01-16-2006, 02:43 PM   #15
Prerunner1982
Prerunner1982's Avatar
dave, my wifes Maxima had that problem, she had a small fuel leak on top of the engine..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-16-2006, 04:39 PM   #16
LOHRTBT
LOHRTBT's Avatar
Yeah...I had a small leak at the carb..but i just fixed that one..so now I am at a loss. I guess I could try the fog machine lol.
THe cab has no rot..that is what bothers me.
~Dave~
Old 01-16-2006, 05:07 PM   #17
bluex
bluex's Avatar
Sounds like it has got be be a seal somewhere around the airbox. My truck has dumps right at the axle and half the floor rotted out with no carpet or anything and I dont get any smell in mine. I would look at the airbox, maybe someone removed/damaged the seal changing the heater core or blower motor??
bluex is offline   Reply With Quote
Old 01-16-2006, 05:46 PM   #18
Prerunner1982
i am sure its coming in the airbox/blower area... the issue should be whats causing the smell...
Dave, how long ago did you fix the fuel problem? could be left over fuel still puddled somewhere?
Old 01-16-2006, 06:51 PM   #19
LOHRTBT
LOHRTBT's Avatar
Its dry..I fixed the leak after it sat for 3 days. Just needed to tighten up a nut.
I have a feeling its the blower too...just need to figure out where to seal it up at. Man...its a deathtrap right now lol!!! close the windows and start it up..DEAD.
~Dave~
Old 01-17-2006, 01:00 AM   #20
79BIG10
79BIG10's Avatar
I got a weird guess but it's worth a shot. The T coming off the back of the intake to pull a vacuum for the heater ball may be leaking exhaust fumes into it.
Old 01-17-2006, 01:45 AM   #21
Phuloi68
I have about the same thing you have. I think there may be a little smoke coming from then engine compartment thru the airbox,heater.
When I first got this truck, I wasn't getting any defrost. I was under the dash doing all kinds of things trying to figure out why not(it ended up being a broken vacuum hose on the intake manifold). In the process I was playing with the flapper door cable adjustment. I know for a fact it is not adjusted correctly and does not properly seal, been to lazy to get back under and adjust it correctly. I think this allows some smoky, or exhaust, fumes from the engine compartment into the cab. Because this is my "beater", I just keep the window down a little while I run for a part or something.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 01-17-2006, 10:56 PM   #22
marvxyz1
marvxyz1's Avatar
I'd check for rust holes around the gasolene filler tube
Old 01-18-2006, 10:05 AM   #23
Eyegore
What Hump?
Eyegore's Avatar
Dave, my 86 had the same smell and it to had several miles on the truck. After I replaced the engine it seems to have disappeared, perhaps greater vaccum to properly close and open the fresh air venting to the a/c. You may want to check the tube going into your blower motor from the case and the blower motor itself, perhaps running a bead of silicone around the base of the motor sealing it.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-19-2006, 12:58 AM   #24
jermasaurus
jermasaurus's Avatar
My passenger side valve cover was leaking in the back and running down the head and made its way to the manifold.
The fan would just blow smoke at the firewall, and with the blower motor on it would come right in. The cab would get kind of cloudy like you mentioned and smell like smoke/fumes.
You may not even notice the smoke with a clutch fan moving all the time.
Maybe check that out.
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
