Old 07-16-2002, 11:13 PM   #1
matt_field
matt_field's Avatar
found a 327 what should i do?
i found a 327 in a 66 impala in town here, i didnt get numbers off it but im going back to do that.. its going in my 67 truck so its close years. Right now in the truck is a 292 6 cyl, my dad thinks i should keep that but id like to be able to go down the highway at a normal speed and have the sound of a V8 its also a 3 on the column, What should i do? oh yeah.. 125.00 for the 327 and needs to be rebuilt, it also has a 2 bbl on it
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 07-17-2002, 12:36 AM   #2
Jesse 67 c-10
Jesse 67 c-10's Avatar
is the 292 lacking power or just buzzing a bit too much at hiway speeds? lol, been there done that! A gear change or different tranny would help a lot with that. spend $125 on a tune up and a nice sounding muffler for your 6 and it might change your mind, if the 6 is still good that is. I put a 327 in mine and I like it a lot but there are a few things I miss from my old 250, not the fact that it was toast thought! You'll probably spend a load of cash on re-building that 327, that cash could be used to hop up your 6 a bit, manifold a 4 barrel, header, cam, nice exhaust. but it all depends on the given situation. 327 is my sb of choice! I'd rather hop the 6 than put a stock 2 barrel 327 in if they were both running good. Your chioce. Good luck!
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 07-17-2002, 12:48 AM   #3
too many
too many's Avatar
Cool
I agree , that 292 should have GOBS of torque. Gearing is probably "holdin you back" . As for small blocks, 327s are neat , but if you can find a 350, parts to rebuild are much less . Northern has complete kits ( pistons, bearings, rings, cam, oil pump, etc. ,etc.) for around $225- 250 delivered to your door!
too many is offline   Reply With Quote
Old 07-17-2002, 07:36 AM   #4
Chevyc10!
Chevyc10!'s Avatar
Keep the heads if they are double humps and scratch the block. The heads are good for around 300hp if built up right.
68 SWB
The Surgeon General doesn't say anything about smoking a Ford!!!
Would rather be ran over repeatedly by a Chevy than drive a Ford!!!
Paralyzed from the neck up and confined to a hat!
Kathleen, Georgia USA
Chevyc10! is offline   Reply With Quote
Old 07-17-2002, 07:52 AM   #5
fast_dev
fast_dev's Avatar
build the 327 if the truck is going to be a hot rod, everybody and everything has a 350. 327's are like a musclecar legend. as far as not enough motor, my nova has the original 327 and went a best of 13.69 at 102 mph. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 07-17-2002, 08:23 AM   #6
Randy70C-10
Randy70C-10's Avatar
Naaa, don't scratch the block! If you want a 350, I can find one to trade. 327's are bad!!! (in a good way)
Randy70C-10 is offline   Reply With Quote
Old 07-17-2002, 08:21 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
On the heads...I go along the other train of thought, sell them for top $$ to a resto freak,(or give a friend a good deal...either way) and go get some vortecs that will blow them away for 1/2 the price.
Plus, you'll have holes to mount your accesories in the proper locations in the truck.
Old 07-17-2002, 08:49 PM   #8
Chevy409
Giddy up giddy up...
Chevy409's Avatar
"found a 327 what should I do?"
GIVE IT TO ME!
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
Old 07-17-2002, 10:27 PM   #9
jmanz69
Careful, they attack...
jmanz69's Avatar
I have a 327 in mine, and I love it. It's one bad little motor. Everyone has a "350", it's almost as bad a a "Mustang 5.0" Their a dime a dozen, but good 327's are harder to find. I got mine for $100 and it was in boxes. Spent just over $1100 to have it built, and have one sweet motor.
I wouldn't trade it for anything...except maybe a big block.
jmanz69
jmanz69 is offline   Reply With Quote
Old 07-17-2002, 10:46 PM   #10
matt_field
matt_field's Avatar
Angry
bad news.. went to get numbers off it and guess what!?!? my luck its a 283 but theres a 350 crews71 has so i might get that if the price is right, id sure like to have a 327 though maybe have to make a 383 stroker
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-18-2002, 10:16 AM   #11
matt_field
matt_field's Avatar
i meant crew70 i might get the motor, mistake on names
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 07-18-2002, 10:25 AM   #12
Randy70C-10
283 is a bad little motor too if built right. I've never seen one blow up!
