01-15-2006, 07:50 PM | #1 |
faster, faster, faster
TPI Swap Q's
Hey guys, I just picked up a TPI speed density system minus injectors, computer and wiring harness on the cheap and was wondering if you guys with experience can send me in the right direction as far as what to get and where to go for the rest of the parts to get this thing done. It is going on top of my stout 385 with 10.2:1 comp. I want to be able to tune this thing with my laptop for optimal performance and mileage. What brands of ECM's are capable of this, and are there even any aftermarket ECM's available for what I want to do. I will also need a wiring harness, what is a good brand to get? Also, is it possible to port the intake any to make it flow a bit better? I will also need some pretty beefy injectors for this thing, what do you guys recommend? I also have an MSD 6AL box already and the TPI is coming with the dist., can I use the MSD box still? I am pretty sure I can, but I just wanted to check here before I drag out every manual known to man looking for the information. Thanks for all the help. It should be here on Thursday.
I'm going to Law School, wanna debate? It's good practice. |
01-15-2006, 11:39 PM | #2 |
Re: TPI Swap Q's
I think you might have a little trouble with the SD set-up and your engine combo?? I did a Mass Air on a 383 and it works really well.
I used a "painless" harness and it was great. The rest of my set-up is stock.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
01-16-2006, 03:20 AM | #3 |
Re: TPI Swap Q's
painless wiring should work. for ecm, I not sure on a aftermarket ecm. a stock might work but you might have to look at sometthing like superchips for a programable prom for it
01-16-2006, 04:39 AM | #4 |
Re: TPI Swap Q's
The stock computer is fine. You can contact Street and Performance to burn you a chip for it. The serpintine pulleys and TPI setup I purchased from a board member is from them. (Well the TPI was probably polished by them) They can supply you with everything you need, are a bit more than some others but provide all the info you need with a purchase.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-16-2006, 05:52 AM | #5 |
Re: TPI Swap Q's
You can also use the Holley Comander 950 and thier harness and program what ever in to it. The TPI unit has restrictions if this is a high output engine with a lumpy cam, The TPI unit was generally good to about 5200rpm, it makes a nice setup for a basically stock engine and wanting some good lowend tourque and thing above 5200rpm without extensive mods to runners and the base will lack.
I should also note that if you use this system now and use the Comander 950 setup you can then later if you wanted upgrade you setup to a MPI, Stealth Ram, MiniRam or possibly any other type of unit.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 01-16-2006 at 05:53 AM. |
01-16-2006, 09:02 PM | #6 |
Re: TPI Swap Q's
My cam isn't too big. It has just under 500 lift and 110deg. Lobe seperation, a little lumpy, but nothing wild. From what I have read, th eupper RPM limitations are due to flow, and that is why I asked about porting and larger injectors. I also believe it can be converted to to MAF , but that is just what I "heard", so I am not sure. Good tip on the commander system, I will check it out. I'll give my engine builer a call and see if he can give me any advice and let me know what he can do as far as opening up the lungs on this thing.
01-17-2006, 08:41 AM | #7 |
Re: TPI Swap Q's
You can buy aftermarket manifolds, runners and plenum for better flow. You can port the plenum the runners don;t have much material left to port and I guess you could port the manifold. I am going to use an LT1 intake, much easier and much better flow. Check out this place: http://www.lt1intake.com/services.htm
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
01-17-2006, 10:08 AM | #8 | |
Re: TPI Swap Q's
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
01-17-2006, 01:04 PM | #9 |
Re: TPI Swap Q's
How exactly does that intake work? Does it take the place of the TPI intake, as in the throttle body, fuel rails and etc. bolt onto it and that's it?
01-17-2006, 05:39 PM | #10 |
Re: TPI Swap Q's
^Yes most of the TPI stuff will work with it injectors(but not fuel rail), throttle body, computer, wiring and the distributor(after the manifold in modified to accept it. Read over the link I posted it should answer most of your questions.
The LT1 manifold is good for another 1500 rpm over the stock TPI.
