Old 01-16-2006, 01:03 AM   #1
Ole Blue 68
Ole Blue 68's Avatar
SBC Heads
Hey all,
Got a hold of some heads today, casting #3973487 which I believe go back to the early 70's LT1. Think they're worth a trip to the machine shop?
Thanks,
John
Ole Blue 68 is offline   Reply With Quote
Old 01-16-2006, 01:14 AM   #2
gentry69
gentry69's Avatar
Re: SBC Heads
hi i looked up the casting for u they are: 71-72 350 used on 71-71 350 lt1' s and they are 75cc didnt say what valves are in them are they 202/1.6 or 194-1.5s
gentry69 is offline   Reply With Quote
Old 01-16-2006, 01:17 AM   #3
gentry69
gentry69's Avatar
Re: SBC Heads
to answer your ? i guess if it were me i would
Old 01-16-2006, 01:38 AM   #4
Ole Blue 68
Re: SBC Heads
Thanks gentry, I can probably get them done for about $150 or $175.
Old 01-16-2006, 01:47 AM   #5
gentry69
gentry69's Avatar
Re: SBC Heads
hey no prob glad i could help.
Old 01-16-2006, 01:49 AM   #6
bighead
Re: SBC Heads
Sell them to a vette guy and buy some good heads. The performance of those are ok but some vortec's or darts are better and would cost less brand new than to fix the old ones. They will need hardened seats installed, maybe guides, valves, surfaced or ??? Just MHO, bighead
bighead is offline   Reply With Quote
Old 01-16-2006, 01:58 AM   #7
Ole Blue 68
Re: SBC Heads
The Darts I've seen run about $600 or $700.
Old 01-16-2006, 02:08 AM   #8
gentry69
gentry69's Avatar
Re: SBC Heads
imo i should of bought a new set of darts cause i bought a pair af camel backs for $400 and then spent another 400 beefing them up but i did the works on them. if u just want a good set of heads for a stocker and dont really want to spend a hole lot i would just use the LT1s but if your going to go the hole nine yards then yea prob would sell them and try to buy a newer set of heads
Old 01-16-2006, 02:23 AM   #9
Ole Blue 68
Re: SBC Heads
That's just it, you can get pretty crazy on a set of heads.
Old 01-16-2006, 06:05 AM   #10
Bowtie67
Bowtie67's Avatar
Re: SBC Heads
If these where the performance heads off of the early 70's 350 they where exceptionly prone to cracking and one of the lowest performance heads that GM produced as a performance head, basically pieces of $hit. Sometimes a set of good used heads are a deal, but other times when you get done having them sent to a machine shop and they require any type of machine work, new valves or new guides you could end up paying more than if you just purchased a set of new heads.
Back to your question about taking thm to the machine shop, deffinately, at least have them checked for cracks...
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 01-16-2006, 12:25 PM   #11
71-longbed
Its Magically Delicious
71-longbed's Avatar
Re: SBC Heads
im running those heads on my stock 71 350 .... in my opinion .. there fine heads ....i have over 250k miles on that engine ... they seem to last the test of time (knock on wood)
but if your looking for higher compression .. ditch the 74cc chambers and get yourself some 64cc heads ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 01-16-2006, 12:41 PM   #12
gentry69
gentry69's Avatar
Re: SBC Heads
u can also have the machine shop mill your heads down to at least 67 cc prob get by with 64 i cant remember what i started out with but mine are now about 60cc and it didnt cost much
Old 01-16-2006, 01:31 PM   #13
Ole Blue 68
Re: SBC Heads
What about 882 heads? I see a lot of these being sold but they seem to have the same specs as the 487s.
Old 01-16-2006, 01:43 PM   #14
gentry69
gentry69's Avatar
Re: SBC Heads
you can go to www.mortec.com and check out all the casting #s and descriptions
Old 01-16-2006, 01:52 PM   #15
Ole Blue 68
Re: SBC Heads
Thanks!
Old 01-16-2006, 02:12 PM   #16
olblue81
olblue81's Avatar
Re: SBC Heads
Back in the early 90's I picked up a set and had them port matched and pocket ported. I kept the valves at 1.94/1.50. This was supposed to be the hot setup for very reasonable dollars and keeping the compression 87 octane friendly.
Go here http://chevyhiperformance.com/techarticles/41598/
They have a database of flowbench tests on heads, both GM and aftermarket. You can see the 882 has the best .400" flow numbers of the first 4 factory castings even the L98's. But look at the vortec castings and see how much better they are. 23 cfm at .400 over the 882's.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 01-16-2006, 02:25 PM   #17
Ole Blue 68
Re: SBC Heads
Good info!
Old 01-16-2006, 02:40 PM   #18
olblue81
olblue81's Avatar
Re: SBC Heads
I should also add that no matter whether you go with new heads or have the old ones rebuilt, make sure you spend the money to add screw in rocker studs. My 882's have had several come loose. It is possible to fix on the motor, but in reality, it's better to pull the head to repair.
Stu-
