01-16-2006, 06:43 PM | #1 |
need help quick..73 spindles on a 67-72?
can you use 73 and up drop spindles on a 67 truck? I think I remember something about having to change ball joints.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
01-16-2006, 07:12 PM | #2 |
Re: need help quick..73 spindles on a 67-72?
You have to change upper & lower balljoints and outer tie-rod ends with a custom adjuster to tie the different inner and outer tie-rod ends together.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-16-2006, 08:49 PM | #3 |
just a question... why not just use drop spindles for a 67-72? I see this a lot, why use 73-87's?
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
01-16-2006, 09:21 PM | #4 |
its just $$$$$
correct me if im wrong, but I dont think you have to change the bottom ball joint. you could get a whole center link from a 73-87 truck to keep from getttin the custom tie rod adjuster sleeves.(probably cheaper if you get it from the salvage yard.)
01-16-2006, 10:08 PM | #5 | |
01-16-2006, 10:09 PM | #6 |
67-72 parts collector,…
'71-'72 don't need to change the lower ball joint. '67-'70 will need a different lower ball joint for the '73-up spindle.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-16-2006 at 10:10 PM. |
01-18-2006, 10:42 PM | #7 |
I have a 67 that I converted to 73-87 drop spindles. I also purchased the art upper and lower control arms. anyway I had to change the lower ball joints due to too short of a ball joint. Also you are correct on the custom adjuster for the tie rod ends. Not sure if the 73 center link idea would work or not. I can't see why it wouldn't but never tried it.
01-19-2006, 01:03 AM | #8 | |
01-20-2006, 04:21 PM | #9 |
Hi Scoti, you can use the 73-87 outer tie rod ends if the thread is recut to 5/8" LH from 11/16" RH thread. Then oem 67 adjuster will work as original. I have done 3 sets. I have a pair of 87's ready to go which also fit some others including the 88 3/4 ton LD spindles. We can re-cut yours. Bring beer.
