Old 01-16-2006, 08:34 PM   #1
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Exclamation Shrouds: V-6 vs BB ??
What's the difference between a V-6 and a BB one? I know that look about the same but, are the mounting tabs in the same location? the one in my V-6 has been badly cracked and been wanting to replace it, anybody knows?
Thanks.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 01-16-2006, 08:37 PM   #2
BubbaGreen
Re: Shrouds: V-6 vs BB ??
Not sure about the opening placement, but the opening is the same diameter. However, thickness for the BB is approx 1" to 1-1/2" deeper than the V6 version.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 01-16-2006, 08:50 PM   #3
bisquik65
bisquik65's Avatar
Member Bobs is the V6 man on here....Where are you Bob?
bisquik65 is offline   Reply With Quote
Old 01-16-2006, 09:56 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I remember they were 99% the same. Wes knows the difference too.
Old 01-16-2006, 10:05 PM   #5
Bob B.
Here I am. I would love to give you a straight answer, but..... Anyway, according to the 67-69 GMC parts book, some are the same between Big Block Chevy and GMC V-6. Part #3924932 is the standard shroud for '68 and '69 V-6's, including '67 305's with A/C. It also fits '69 396 V-8's. There is another V-6 shroud listed for '67 351's with A/C. That one is part #3903824, and it doesn't go on any 396 V-8's. What year and what size is your V-6? Does the shroud have a number molded in it?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-16-2006, 10:25 PM   #6
chevy_fatman
Where's my beer?
Bob, that first number you posted, is it the same for '68-'69 trucks with A/C or just for '67 305 with A/C? my V-6 is a '69 305E with A/C, I haven't really looked at the shroud for a number, where should it be located?
Thanks for all the responses guys Paul.
Paul
Old 01-16-2006, 10:45 PM   #7
Joesjunk
Joesjunk's Avatar
I think I still have a shroud from a V-6 truck. It is different than a BB one. I think it is not as wide? I will have to dig it out again. They do "Look" the same though. I will sell it if you need one.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-16-2006, 11:22 PM   #8
Longhorn Man
What you got brewin there Paul?
Old 01-16-2006, 11:55 PM   #9
chevy_fatman
Where's my beer?
shhhh! don't wanna let the cat outta the bag when you going to kali?
Paul
Old 01-17-2006, 12:23 AM   #10
Bob Moore
If you look on top of the core support on the passenger side(battery side) you will notice a captured nut location 2inches toward the center line from the standard radiator holddown location. This is for the GMC V6 radiator and narrow shroud. The shroud is the same in appearance to the big block shroud except it has 2 inches off the passenger side - fan diameter is the same and same location as BB. I just looked at 1 in my basement and measured the difference. The lower edge of the core support also has a provision for the lower holddown location 2 inches from the standard. I believe the V6 shroud would work with either a four core or standard radiator if it was 2 inches narrower.
Let me know if you need pictures or the shroud - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-17-2006, 01:50 AM   #11
Bob B.
3924932 also fits 1/2 ton '68 and '69 305's with A/C, too. The numbers on my shroud are molded in the edge of the fan opening at the bottom. My shroud (3903824) is wide, and the radiator/shroud brackets go in the outer captured nuts on the core support. I have the inboard nut that Bob Moore is talking about, but it is not used.
Old 01-17-2006, 10:42 AM   #12
BobS
BobS's Avatar
The V-6s usually have smaller radiators, it's hard to get them to run warm enough to keep the frost off the windows up here with a big radiator!
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 01-17-2006, 02:15 PM   #13
Erl
Erl's Avatar
There were two sizes used on the GMC V6, a small one and a large one. The large one is part # 3924932 (as stated earlier), the same as 69 big block. The part number is molded into the shroud. It is small and hard to find. Bought one from Wes and it bolted right in.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 01-17-2006, 03:12 PM   #14
Bob Moore
Yes. Mine is the correct smaller one, for the smaller radiator.
vac, 454, T400
more to follow
Old 01-17-2006, 08:05 PM   #15
chevy_fatman
Where's my beer?
Thanks guys! very informative replies, I appreciate it!
Old 01-17-2006, 08:35 PM   #16
Longhorn Man
Paul, a trip is planned for the begining of april.
Old 01-17-2006, 09:21 PM   #17
matthufham
wow we had a bob moore, a bob b, and a bob s. sorry, onto the discussion now.
matthufham is offline   Reply With Quote
Old 01-17-2006, 09:49 PM   #18
Bob B.
Yeah, and we are all GMC V-6 fans. What are the odds?
Old 01-17-2006, 10:05 PM   #19
JAKES 68GMC
Aluminum slot wheels rule...
Don't forget v6 fan #4!!!!!
JAKES 68GMC is offline   Reply With Quote
Old 01-18-2006, 04:29 AM   #20
Bob B.
So it's 3 Bobs and a Jake. I'm good with that!
Old 01-20-2006, 08:04 PM   #21
Joesjunk
Joesjunk's Avatar
I found mine, It has a part # 3903752. It is very nice if you need one. I can get a pic if you need it.
Old 01-22-2006, 10:30 PM   #22
Joesjunk
Joesjunk's Avatar
Checking to see if you still need it. I have someone else asking if you pass.
Thanks, Joe
